953" Hemi going on the dyno........ #485808
10/01/09 11:29 PM
10/01/09 11:29 PM
Illinois
CRE2004 Offline OP
super gas
CRE2004  Offline OP
super gas
Illinois
Well,
One 478" and one 475" anyway
478 is a pump gas 4.15 stroke, hydraulic roller, edelbrock/MP aluminum heads, Diamond forged pistons, comp hydraulic roller, indy rockers, eddy thunder series 650 carbs, MP repro intake and is headed for a nice E body.
The 475 is a pump gas solid roller. 4.15 stroke, diamond pistons, comp solid roller, original iron heads, stock rockers, stock carbs and going back in a 71 hemi charger.
It should be a fun pair to compare
Re: 953" Hemi going on the dyno........ [Re: CRE2004] #485809
10/02/09 01:59 AM
10/02/09 01:59 AM
IL
Dart451 Offline
Dart451  Offline
IL
Want my click back
When you getting results?
Re: 953" Hemi going on the dyno........ [Re: Dart451] #485810
10/02/09 07:54 AM
10/02/09 07:54 AM
Illinois
CRE2004 Offline OP
super gas
CRE2004  Offline OP
super gas
Illinois
Should have some data next week
Re: 953" Hemi going on the dyno........ [Re: CRE2004] #485811
10/02/09 08:51 AM
10/02/09 08:51 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
bbbbbooooooo ... Tease , this reminds me of being teased by the X
Re: 953" Hemi going on the dyno........ [Re: JohnRR] #485812
10/02/09 09:36 AM
10/02/09 09:36 AM
Illinois
CRE2004 Offline OP
super gas
CRE2004  Offline OP
super gas
Illinois
What? You expected only one engine?
Re: 953" Hemi going on the dyno........ [Re: CRE2004] #485813
10/02/09 10:03 AM
10/02/09 10:03 AM
acworth / N. georgia - south e...
cheapstreetdustr Offline
unless the hydralic cam is alot larger.
or the aluminum heads have alot of work done.
my vote is the solid cam 475" makes more pwer.
are those iron heads cleaned up?
cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: 953" Hemi going on the dyno........ [Re: cheapstreetdustr] #485814
10/02/09 09:20 PM
10/02/09 09:20 PM
Illinois
CRE2004 Offline OP
super gas
CRE2004  Offline OP
super gas
Illinois
Iron heads are fresh, but no clean up work on the ports. New guides, new valves, springs, locks retainers, etc... These aren't going to be big power engines. Drive-ability was a big concern. Both are 10:1 CR pieces. Camshafts are virtually identical (both very small) with one being a solid roller and the other a hydraulic roller.
Re: 953" Hemi going on the dyno........ [Re: CRE2004] #485815
10/02/09 10:15 PM
10/02/09 10:15 PM
Indiana
maxie Offline
maxie  Offline
Indiana
they sound somewhat close to what I am building.
472 inch
Indy heads
stage V intake
600 lift solid roller 248 at 50
dick landy roller rockers
I am interested in seeing the power they make.
