Re: 360 crank in a 340 block
[Re: goldmember]
#485501
10/02/09 09:06 AM
10/02/09 09:06 AM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
Ever consider just getting a 360?
A 360 crank in a 340 is the same as a 360 with a .040 overbore.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
[Re: CJK440]
#485502
10/02/09 10:54 AM
10/02/09 10:54 AM
Posts: 19 alberta, canada
drtsprt
alberta, canada
yes, i'm just covering all options. i'm trying to find an older 360 block. i really want to do a stroker but won't be able to afford it this year so i wanted to freshen up and gain as much cubes for cheap.
[Re: drtsprt]
#485503
10/02/09 12:11 PM
10/02/09 12:11 PM
Posts: 75,092 A Banana Republic near you.
JohnRR
if that's the case I would just look for a good running 360 and do the stroker over time ?
[Re: JohnRR]
#485506
10/02/09 01:01 PM
10/02/09 01:01 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
The 360 to 340 stroker can be done inexpensively and yeald 372 (+.030) to 378 (+.060). The crank likely needs turning anyways and add about $100 to have Crank turned down to 340 size total job will be 250 to 300 turned and polished. Pistons are shelf for many manufactures so no more than a proper rebuild for either 260 or 340!!! Check out the 360 pistons with .070 suggestions for 340 block listed at Summit too http://chucker54.stores.yahoo.net/keithblack.htmlThat said true stroker kits with or without H beam rods fully balanced come in at not much more than buying everything seperate and have a 360 crank cut down!! http://chucker54.stores.yahoo.net/inba1.html
[Re: Dodgem]
#485507
10/02/09 01:51 PM
10/02/09 01:51 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
you can buy a scat cast crank 340 mains 3.58 stroke for $366 from summit.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
