block i.d. stamp 340
#485202
10/01/09 02:46 PM
10/01/09 02:46 PM
Posts: 1,237 North Central, Indiana
Roughbird72
a friend bought a 73 340 roadrunner.i wasn't able to get under the car to look at the casting number.i took down the stamp on the i.d. pad EW340 P29050127.can anyone tell me what year engine it is?
72 Plymouth Roadrunner 11.08@123.25
Re: block i.d. stamp 340
[Re: Roughbird72]
#485204
10/01/09 03:30 PM
10/01/09 03:30 PM
Posts: 25,919 Rio Linda, CA
John_Kunkel
Rio Linda, CA
2905 is the build date July 11, 1969 but it could be a '70 model year, the partial VIN stamped in the lower block will tell for sure.
[Re: RobX4406]
#485207
10/01/09 04:21 PM
10/01/09 04:21 PM
Roughbird72
thanks guys.i'll have to check the vin stamping,but i was pretty sure it wasn't a 73 340.guess i'd better pull a valve cover & see what heads are on it too.
[Re: ph23vo]
#485208
10/01/09 06:31 PM
10/01/09 06:31 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
EW340 P29050127
E = 1969 model year install but my money is on it being an F (1970) W = Windsor Ontario Assembly Plant 340 = 340 CID P = Premium Fuel 2905 = July 11 1970 Assembly Date (which if correct means that the preceding E is actually an F) 0127 = 127th engine assembled that day
[Re: 72 RR DUDE]
#485211
10/03/09 10:01 AM
10/03/09 10:01 AM
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
27p0930-340-6 2b117718 or 6
Front of block 72 HM 340R
27p0930-340-6 ("p" is an 8) = 340 block casting number
2b117718 or 6 = VIN sequence number
72 = 1972 Model year H = 1972 model year M = Mound Road Assembly Plant 340 = CID R = Regular Fuel
You left off some numbers on the front of the block, 72HM340RXXXXXXX?
[Re: ScottSmith_Harms]
#485213
10/03/09 11:54 AM
10/03/09 11:54 AM
Posts: 308 Turneffe
BJohnson
Turneffe
EW340 P29050127
2905 is 7/11/1969.
#485215
10/03/09 03:39 PM
10/03/09 03:39 PM
Posts: 308 Turneffe
BJohnson
Turneffe
2905 is 7/11/1969
Not according to my 10,000 day calender it's not
Perhaps you need a new calendar.
[Re: John_Kunkel]
#485216
10/03/09 04:33 PM
10/03/09 04:33 PM
John_Kunkel
Rio Linda, CA
2905 IS July 11, 1969, I corrected my original reply (having a senior moment). This is a really late build to be installed in a '69 car but the numbers don't lie.
