block i.d. stamp 340 #485202
10/01/09 02:46 PM
10/01/09 02:46 PM
North Central, Indiana
Roughbird72 Offline OP
a friend bought a 73 340 roadrunner.i wasn't able to get under the car to look at the casting number.i took down the stamp on the i.d. pad EW340 P29050127.can anyone tell me what year engine it is?
72 Plymouth Roadrunner 11.08@123.25
Re: block i.d. stamp 340 [Re: Roughbird72] #485203
10/01/09 03:21 PM
10/01/09 03:21 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
2905 is a 70 engine dan
Re: block i.d. stamp 340 [Re: Roughbird72] #485204
10/01/09 03:30 PM
10/01/09 03:30 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
2905 is the build date July 11, 1969 but it could be a '70 model year, the partial VIN stamped in the lower block will tell for sure.
Re: block i.d. stamp 340 [Re: John_Kunkel] #485205
10/01/09 03:34 PM
10/01/09 03:34 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
john is right it would probably be in a 71 car but is a 70 engine technically dan
Re: block i.d. stamp 340 [Re: ph23vo] #485206
10/01/09 03:51 PM
10/01/09 03:51 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
EW340
E = 1969.
You sure about that stamping?
Would be an F for 1970
G for 1971
Look on the pass side pan rail for the VIN stamping
Re: block i.d. stamp 340 [Re: RobX4406] #485207
10/01/09 04:21 PM
10/01/09 04:21 PM
thanks guys.i'll have to check the vin stamping,but i was pretty sure it wasn't a 73 340.guess i'd better pull a valve cover & see what heads are on it too.
Re: block i.d. stamp 340 [Re: ph23vo] #485208
10/01/09 06:31 PM
10/01/09 06:31 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
EW340 P29050127
E = 1969 model year install but my money is on it being an F (1970)
W = Windsor Ontario Assembly Plant
340 = 340 CID
P = Premium Fuel
2905 = July 11 1970 Assembly Date (which if correct means that the preceding E is actually an F)
0127 = 127th engine assembled that day
Re: block i.d. stamp 340 [Re: ScottSmith_Harms] #485209
10/01/09 06:48 PM
10/01/09 06:48 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
which is what i stated in my orig response
Re: block i.d. stamp 340 [Re: ph23vo] #485210
10/03/09 09:52 AM
10/03/09 09:52 AM
Hamburg, Pa.
72 RR DUDE Offline
72 RR DUDE  Offline
Hamburg, Pa.
So here is the 340 I have. What does it decode out to be.
Side of block
27p0930-340-6
2b117718 or 6
Front of block
72 HM 340R
Re: block i.d. stamp 340 [Re: 72 RR DUDE] #485211
10/03/09 10:01 AM
10/03/09 10:01 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
27p0930-340-6
2b117718 or 6
Front of block
72 HM 340R
27p0930-340-6 ("p" is an 8) = 340 block casting number
2b117718 or 6 = VIN sequence number
72 = 1972 Model year
H = 1972 model year
M = Mound Road Assembly Plant
340 = CID
R = Regular Fuel
You left off some numbers on the front of the block, 72HM340RXXXXXXX?
Re: block i.d. stamp 340 [Re: 72 RR DUDE] #485212
10/03/09 10:03 AM
10/03/09 10:03 AM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Side of block
27p0930-340-6
2b117718 or 6
Front of block
72 HM 340R
Casting number
2(1972 model) B = car built at Hamtramck 117718 remainder of VIN sequence number
72= 72 model year
H= 72 model year
M= Assembled at mound road engine plant
340= CID
R= regular fuel
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: block i.d. stamp 340 [Re: ScottSmith_Harms] #485213
10/03/09 11:54 AM
10/03/09 11:54 AM
Turneffe
BJohnson Offline
BJohnson  Offline
Turneffe
EW340 P29050127
340 = 340 CID
P = Premium Fuel
2905 is 7/11/1969.
Re: block i.d. stamp 340 [Re: BJohnson] #485214
10/03/09 12:10 PM
10/03/09 12:10 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
2905 is 7/11/1969
Not according to my 10,000 day calender it's not
Re: block i.d. stamp 340 [Re: ScottSmith_Harms] #485215
10/03/09 03:39 PM
10/03/09 03:39 PM
Turneffe
BJohnson Offline
BJohnson  Offline
Turneffe
2905 is 7/11/1969
Perhaps you need a new calendar.
Re: block i.d. stamp 340 [Re: John_Kunkel] #485216
10/03/09 04:33 PM
10/03/09 04:33 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
2905 IS July 11, 1969, I corrected my original reply (having a senior moment). This is a really late build to be installed in a '69 car but the numbers don't lie.
Re: block i.d. stamp 340 [Re: John_Kunkel] #485217
10/03/09 11:22 PM
10/03/09 11:22 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes, I was mistaken. The 10,000 day calender In Galen's White Book shows 2905 as July 11 with 1970 at the top of the page, but below in fine print he does show 1969/1970 on the same page so it was an oversight on my part, July 11, 1969 it is.
