setting valves #484848
09/30/09 10:08 PM
09/30/09 10:08 PM
in front of the computer
8
80arrow Offline OP
80arrow  Offline OP
I know that this was covered not to long ago but I'm not smart enough to find it again. I want to know how you guys set your valves with a long duration cams. Thanks alot, Clint
Re: setting valves [Re: 80arrow] #484849
09/30/09 11:18 PM
09/30/09 11:18 PM
Rotate the motor over until the exhaust valve just starts to open, set the intake valve lash Rotate the motor over again until the intake valve opens all the way and starts to close(1/3 to 2/3 closed) and then set the exhaust
Re: setting valves [Re: Cab_Burge] #484850
10/01/09 08:54 PM
10/01/09 08:54 PM
nc
E
earthmover Offline
earthmover  Offline
E
nc
sorry to hi jack but is it the same for short dura. cams as well or could you exp. how to do that thanks
Re: setting valves [Re: earthmover] #484851
10/01/09 11:05 PM
10/01/09 11:05 PM
That method works for all cams, no matter the size or duration, hydraulics are a little different but very near the same
Re: setting valves [Re: Cab_Burge] #484852
10/01/09 11:10 PM
10/01/09 11:10 PM
8
80arrow Offline OP
80arrow  Offline OP
thank you
