No headlamps on 71 E-Body.....fuse or relay missing ?? #484303
09/30/09 05:35 PM
09/30/09 05:35 PM
NORTHERN VA
THESHAKERPROJECT Offline OP
NORTHERN VA
All 4 lites do not lite. I have bat voltage at the dimmer when the headlamps switch is on. Is there a fuse or relay Im missing ?? ALL the wires in the car are new (MH) and the car was apart when I got it. ALL the other lites work ....but no headlites. I did try to bypass the dimmer. Any Ideas ???
Re: No headlamps on 71 E-Body.....fuse or relay missing ?? [Re: THESHAKERPROJECT] #484304
09/30/09 06:00 PM
09/30/09 06:00 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Did you hook up the headlight grounds at the core support? If you did is the metal clean under them? Have you checked at the headlight bulb plugs for power? There is no fuse or relay that would cause this.
Re: No headlamps on 71 E-Body.....fuse or relay missing ?? [Re: stumpy] #484305
09/30/09 06:13 PM
09/30/09 06:13 PM
NORTHERN VA
NORTHERN VA
I have the ground wire at the core support hooked up and clean ground (marker lites work as do the front turn sig ) but no 12V at the red wire at the headlamps.
Re: No headlamps on 71 E-Body.....fuse or relay missing ?? [Re: THESHAKERPROJECT] #484306
09/30/09 06:23 PM
09/30/09 06:23 PM
Poplar Bluff, Mo. 63901
2
268RTs4ME Offline
268RTs4ME  Offline
Go to you dimmer switch, that is prabably your proble, bypass and see if you get lights..
Re: No headlamps on 71 E-Body.....fuse or relay missing ?? [Re: 268RTs4ME] #484307
09/30/09 07:47 PM
09/30/09 07:47 PM
NORTHERN VA
NORTHERN VA
I bypassed the dimmer and I had 12v at the hot (green ) but when jump the green to red I get no volts at both ends of the jumper wire so the wire is grounding out someware. IM gonna break out my new Powerprobe in the am and try again.
Re: No headlamps on 71 E-Body.....fuse or relay missing ?? [Re: THESHAKERPROJECT] #484308
09/30/09 08:07 PM
09/30/09 08:07 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
There are three wires on the dimmer, One hot, one high beam. one low beam. Did you try going from the hot to both of the other two one at a time?
Re: No headlamps on 71 E-Body.....fuse or relay missing ?? [Re: THESHAKERPROJECT] #484309
09/30/09 08:15 PM
09/30/09 08:15 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
You have high resistance in the power circut.. when you apply an electrical load it pulls the voltage down to zero... try unplugging the headlights then rerun your voltage test... If you still have 12v with the dimmer jumpered look for a bad connection in the power circut...
Re: No headlamps on 71 E-Body.....fuse or relay missing ?? [Re: 1_WILD_RT] #484310
10/02/09 12:54 AM
10/02/09 12:54 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
headlights doesn't have really a fuse protection ( just the main fuse link )
Re: No headlamps on 71 E-Body.....fuse or relay missing ?? [Re: THESHAKERPROJECT] #484311
10/02/09 07:37 AM
10/02/09 07:37 AM
On the open road
Hrtbkr Offline
Hrtbkr  Offline
On the open road
The head light circuit is protected by a circuit breaker built into the headlight switch. Did the car ever have headlights? It could be the switch has gone bad.
While outside on the turnpike They got this new hit tune Where thrills become as cheap as gas And gas as cheap as thrills
Re: No headlamps on 71 E-Body.....fuse or relay missing ?? [Re: Hrtbkr] #484312
10/02/09 10:34 AM
10/02/09 10:34 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If he gets power to the floor dimmer then the headlight switch is working.
