Stage V intake VS a rat roaster dyno numbers anybody #483872
09/29/09 10:07 PM
09/29/09 10:07 PM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
Has anyone ever dyno'd a motor with a stage V 2 fours intake and then the same motor with a rat roaster.
I acquired a rat roaster today and I have a stage V. I have about everything to build another motor and was wandering which would make the better numbers.
I think one of the pros is that the rat roaster uses a stock air cleaner.
Anyone?
Re: Stage V intake VS a rat roaster dyno numbers anybody [Re: maxie] #483873
09/29/09 10:35 PM
09/29/09 10:35 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
That would be interesting to see how the old RR stacks up. I would guess the RR might be down as much as 10% (somewhat based on the Indy crossram vs. single Dominator and two 4bbls on the Indy TR tests). I would also like to see the EGT temps for each cylinder when comparing the intakes. I'm assuming we are talking about the two AFB inline RR.
Floyd Lippencott IV
Re: Stage V intake VS a rat roaster dyno numbers anybody [Re: mr_340] #483874
09/29/09 10:40 PM
09/29/09 10:40 PM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
That is what I got is the two four top. I also was told today that there were two or three different versions of the rat roaster. The later one had a divider in it from what I was told. Basiclly there is a wall right down the middle of it that seperates the right and left side.
Re: Stage V intake VS a rat roaster dyno numbers anybody [Re: maxie] #483875
09/29/09 11:32 PM
09/29/09 11:32 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
Yep, one twin AFB, one Crossram Holleys and one single 4500 top. I think they all had different bottoms to correct for different fuel distribution problems.
Floyd Lippencott IV
Re: Stage V intake VS a rat roaster dyno numbers anybody [Re: mr_340] #483876
09/29/09 11:34 PM
09/29/09 11:34 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
Twin AFBs, inline.
Floyd Lippencott IV
Re: Stage V intake VS a rat roaster dyno numbers anybody [Re: mr_340] #483877
09/29/09 11:36 PM
09/29/09 11:36 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
4500 RR3.
Floyd Lippencott IV
Re: Stage V intake VS a rat roaster dyno numbers anybody [Re: mr_340] #483878
09/30/09 05:43 AM
09/30/09 05:43 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
The Stage V will out perform the RR. The RR has issues in getting the fuel down the runners. Without modifications, its probably about the lowest performance intake you could use these days.
Re: Stage V intake VS a rat roaster dyno numbers anybody [Re: Dragula] #483879
09/30/09 07:44 AM
09/30/09 07:44 AM
Richmond Va, KeislerTKO 60...
V
VanishPt Offline
VanishPt  Offline
V
not to hijack this,,,,, but does anyone have any info on if there is a need for staggered jetting on the Stage 5? My number 8 cylinder's plug is always the lightest color
Re: Stage V intake VS a rat roaster dyno numbers anybody [Re: VanishPt] #483880
09/30/09 08:09 AM
09/30/09 08:09 AM
Northern N.J.
hemi_doug Offline
hemi_doug  Offline
Northern N.J.
You running power brakes?
71 440-6 4spd & 69 Hemi 4spd
Re: Stage V intake VS a rat roaster dyno numbers anybody [Re: hemi_doug] #483881
09/30/09 12:01 PM
09/30/09 12:01 PM
V
VanishPt Offline
VanishPt  Offline
V
no power brakes
Re: Stage V intake VS a rat roaster dyno numbers anybody [Re: VanishPt] #483882
09/30/09 12:25 PM
09/30/09 12:25 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Stage V will out perform the RR everywhere except at top end charge(above 7500 rpm)if jetting is correct.The RR is doggy even with modifications on low end and midrange,A single plane large volume intake and a dominator will out perform the RR with daul carbs.
Re: Stage V intake VS a rat roaster dyno numbers anybody [Re: VanishPt] #483883
09/30/09 01:48 PM
09/30/09 01:48 PM
Northern N.J.
hemi_doug Offline
hemi_doug  Offline
Northern N.J.
no power brakes
The reason I asked is because I had a simlar problem with mine...found a leaky vacuum booster caused #8 to go lean.....
