Re: popping the cherry?
[Re: JohnRR]
#482936
09/30/09 03:19 PM
09/30/09 03:19 PM
Posts: 4,848 Memphis
HemiRick
Memphis
The manual VB question gets to my question....How to do a burnout with a stock Valve body....?
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: HemiRick]
#482937
09/30/09 03:48 PM
09/30/09 03:48 PM
Posts: 75,020 U.S.S.A.
JohnRR
U.S.S.A.
I've always just done it in drive , stand on the brake and it will shift thru the gears , I was young and didn't know any better ..
with a stock VB if you put it in low the rear band applies , not a bad thing , shift to second and then to drive , if you have the room (and the HP) for a john force type burnout
