440 build opinions
#482695
09/28/09 04:56 PM
09/28/09 04:56 PM
Posts: 132 Windsor, Ontario
project74
Windsor, Ontario
In the planning stages of a 440 build and could use a little guidance. The specs so far. -78 block .030 -Stock cast crank and rods -452 heads with stock valve size, maybe upgrade to 2.14/1.81 if worthwhile, maybe a bowl blend. -Whichever piston puts me in the 9.5:1 range -Lunati or Comp cam in the 260/276 duration .475/.490 lift range. -HP manifolds running through 2.5" duals with crossover. -3.23 suregrip rear -28" tires -727 with 2200-2500 stall -Car is big, around the 4000 lb mark (1970 Fury) -Wanted to go Performer RPM for an intake but I'll have hood clearance issues. I've got a good line on a Holley Street Dominator atm. Even though it's a single plane would it still work ok with a combo like this due to it's lower profile? The regular Performer or CH4B is an option but would those move enough air and keep up with a bit of head work/valve changes? Car will be for street and won't very often see the top side of 5500 rpm. Just want it to be able to move the way it should whether from a stop or punching it at 40mph. Many thanks in advance for any and all input.
1970 Fury III, 318, 4 dr hardtop, aka "The Fridge"
Re: 440 build opinions
[Re: DaytonaTurbo]
#482697
09/28/09 06:17 PM
09/28/09 06:17 PM
project74
Windsor, Ontario
Forgot to mention, carb will be a '74 TQ from a 440. May be contacting DemonSizzler about that one.
I'd love to have aluminum heads, DT, but that would blow my budget way up considering the deal I've got in the works for some minor head work. More than likely, $'s will dictate sticking with the stock valve sizes. 1/4 time wise, if I were to take her down the 1420 some day I'd be thrilled with mid to high 13's.
[Re: JohnRR]
#482702
09/29/09 10:12 AM
09/29/09 10:12 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
CH4B and voodoo 60303 cam. pistons, use the KB flat tops (237's IIRC)
[Re: JohnRR]
#482703
09/29/09 02:07 PM
09/29/09 02:07 PM
DaytonaTurbo
Manitoba, Canada
The CH4B will work fine with that combo also
I agree, for this combo the CH4B is perfect. When they did the 383 intake shootout, I think the 383 version of the ch4b actually kept up with the edelbrock rpm version of the 383 intake and I think the dp4b actually had a tiny bit more torq in the bottom end. When they tested with stock heads anyway...
[Re: STLDuster]
#482705
10/02/09 09:04 AM
10/02/09 09:04 AM
Posts: 75,092 A Banana Republic near you.
JohnRR
I just looked at this again , I'm working on pretty much an identical build to this engine. I'm building for quench with the 452's shooting for the same compression goal, it will be running stock HP manifolds and an Ebrock thunder 800. The CH4B would be the better intake choice, stall doesn't really need to be a lot over stock ... 2000-2200ish , after talking with fast68plymouth his recommendation on the cam is a Comp xe268 (the big summit grind was tossed in there also). Good midrange torque, good vacuum signal, should be a zero hassle engine which is what the end user needs.
