Need killer 904 #481695
09/27/09 05:22 PM
09/27/09 05:22 PM
Central,Ohio
FASTFISH420 Offline OP
Central,Ohio
Hey all you 904 guru's..What kind of parts will I need to build a 904 to stay together behind my car??
We are talking to be able to handle 1000hp,9000rpm shifts,3050 pounds..I looked on TCS web site and they dont have awhole bunch of parts for the 904..I see AandA sells one for 6500 bucks..For that kind of money I would just call Joel on Joy in Michigan and buy a pro-flite from him using Pro-trans parts..
I am thinking about building one for a test session..I have a good valvebody and changing the conveter would not be a problem..I would like to have straight cut gearing,but AandA does not show them???Would like to have a 2.28 first gear..the 2.45 would cause my car to flip over backwards.
Dont want to go with a 2-speed..not as fun..would love to have a liberty..
Any 904 guys want to loan me a trans
My 727 is For Sale in the race section..if anybody is interested.
1969 Barracuda 8 second all/motor small block 2014 Shelby GT500 Mustang Uratchko Racing Engines www.URE-RACING.com
Re: Need killer 904 [Re: FASTFISH420] #481696
09/27/09 05:52 PM
09/27/09 05:52 PM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
Same question about a 904 trans that will live, but for only 350 HP, less than 3000# total, max of 6000 RPM shifts. I may be slow, but I want to do it consistently and without too much breakage.
This is the land of the free because of the brave
Re: Need killer 904 [Re: FASTFISH420] #481697
09/27/09 05:57 PM
09/27/09 05:57 PM
Rudolph, Ohio
moparguy7074 Offline
Rudolph, Ohio
Whatcha doing, switching to a certain nascar engine?
Re: Need killer 904 [Re: moparguy7074] #481698
09/27/09 06:21 PM
09/27/09 06:21 PM
Central,Ohio
Central,Ohio
Nascar engine???talking about my 416 inch W8 engine..
Re: Need killer 904 [Re: FASTFISH420] #481699
09/27/09 06:26 PM
09/27/09 06:26 PM
Call Dave Smith at Pro Trans 661-940-7400, 9:00 A.M. to 5:30 PM PDT Mon-to fridays usually, for the best 904 parts availble
Re: Need killer 904 [Re: Cab_Burge] #481700
09/27/09 06:32 PM
09/27/09 06:32 PM
Central,Ohio
Central,Ohio
Talked with Dave many times...just dont want to spend the $$$ for a SS/AH trans right now..but I am probably going to have to breakdown and do that just thing
Re: Need killer 904 [Re: FASTFISH420] #481701
09/27/09 06:37 PM
09/27/09 06:37 PM
Dave makes and sells a lot of parts, not just complete transmissions He is glad to sell just parts as well as complete trans and converters packages
Re: Need killer 904 [Re: Cab_Burge] #481702
09/27/09 07:25 PM
09/27/09 07:25 PM
Central,Ohio
Central,Ohio
Last time I talked with Dave he would not sell any of his pro-flite parts..but that was awhile ago..maybe things have changed?
Re: Need killer 904 [Re: FASTFISH420] #481703
09/27/09 07:40 PM
09/27/09 07:40 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
I'd give John Cope a call if you want another opinion - CRT will always discuss your plans without trying to oversell you products...
Re: Need killer 904 [Re: DJVCuda] #481704
09/27/09 08:04 PM
09/27/09 08:04 PM
New England
Tech Instructor Offline
New England
I Would contact Rick Allison at A&A trans in Indiana.
Re: Need killer 904 [Re: Tech Instructor] #481705
09/27/09 08:12 PM
09/27/09 08:12 PM
Kansas, USA
V
Venomvpr900 Offline
Venomvpr900  Offline
V
Kansas, USA
Rick is the man
1987 D-100 SWB, 390hp/360ci Mopar Performance Crate, Built 998 trans, 9.25 axle with sure-grip and 3.92's - 3960#'s with driver 13.83 @ 96.36 1.98 60 ft 2003 Dodge Ram 2500 HD 5.7ltr HEMI!!!
Re: Need killer 904 [Re: Venomvpr900] #481706
09/27/09 08:18 PM
09/27/09 08:18 PM
Hemiroid Offline
Hemiroid  Offline
I know Joel built the trans in Chuck @ Best Machine's 65 Coronet and it lived there. His car was right at weight (3350) and he makes/made about 1070 hp.
Re: Need killer 904 [Re: FASTFISH420] #481707
09/27/09 08:20 PM
09/27/09 08:20 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
I heard he was currently 8 months out on complete Pro-flites.
Re: Need killer 904 [Re: Hemiroid] #481708
09/27/09 08:23 PM
09/27/09 08:23 PM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
Joel or dave would be my first two picks. i do know that both are VERY BUSY right now though
Re: Need killer 904 [Re: prochargedhemi] #481709
09/27/09 08:48 PM
09/27/09 08:48 PM
Central,Ohio
Central,Ohio
I know both are always very busy..I am pretty sure Chucks car is a 727 with a 2.28 straight cut deal...it is not a 904 internal 727..
If I had almost 600 cubic inches like Chuck and most of them boys at Milan.. I wouldn't be worried about a lightweight trans..The one I have would work great..
Re: Need killer 904 [Re: FASTFISH420] #481710
09/27/09 08:52 PM
09/27/09 08:52 PM
Hemiroid Offline
Hemiroid  Offline
I know you're right about the 2.28 1st, not sure if it's all light weight or not. The lightweight stuff from Smith lives to a point in SS/AH cars, but they're high maintenance.
Re: Need killer 904 [Re: Hemiroid] #481711
09/27/09 09:03 PM
09/27/09 09:03 PM
Vacherie, Louisiana
SuperStocker Offline
super gas
super gas
Vacherie, Louisiana
Would you happen to know anyone that runs comp eliminator or a mopar superstocker? They just might have something in the neighborhood of what your looking for.
Re: Need killer 904 [Re: SuperStocker] #481712
09/27/09 09:18 PM
09/27/09 09:18 PM
Central,Ohio
Central,Ohio
Most of the Comp guys run the pro-flite with a GM converter and adapter plate..I would want to use my 7-inch converter for a 727 input shaft.You find some Pro-trans 727 hemi trans..but the guts would have to be changed over to a smallblock case and most of the hemi guys run a 2.28 to 2.34 first gear..that is alittle agressive for my combo..I would need somewhere in the range of a 2.14 to 2.18..
I am just going to have to breakdown and buy a trans from Dave and use my valvebody..
I know this 727 I have been running is just robbing power out of my motor...I bet a pro-flite would be a good 2 tenth quicker..plus..running this 727 with the large internals at 9000rpm is alittle scary
Re: Need killer 904 [Re: FASTFISH420] #481713
09/27/09 09:40 PM
09/27/09 09:40 PM
Vacherie, Louisiana
super gas
super gas
Vacherie, Louisiana
I would try some of the comp forums just to see what's out there. Someone might just have the gearset your seeking. FWIW, I wouldn't be afraid to try a 2.28 first in your ride...
Re: Need killer 904 [Re: SuperStocker] #481714
09/27/09 09:51 PM
09/27/09 09:51 PM
Central,Ohio
Central,Ohio
I agree 100%
I sure would try the 2.28 904 gearset..
