Re: What's the trick to keep flex plate bolts tight? [Re: challenger73400] #481018
09/27/09 07:50 PM
09/27/09 07:50 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
What balancer is on engine?
440 source SFI balancer. No unusual vibrations.
Thanks guys, I'll put red lock tight and some bowinkle on the bolts!
BTW. how does a cracked crank cause the flex plate bolts to come loose? Added vibration?
you will not feel the vibration that will loosen the blots. I had this same deal on SM block mopar street car even went as far as to weld the bolts it just broke welds. I put good balancer on it never had bolts back out again.(BHJ at the time) If you have any other balancer to try I would start with that.
Re: What's the trick to keep flex plate bolts tight? [Re: W5DART66] #481019
09/27/09 08:11 PM
09/27/09 08:11 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
do you have the bell notched out so you can get a good pull on the wrench?
Re: What's the trick to keep flex plate bolts tight? [Re: 602heavy] #481020
09/27/09 08:20 PM
09/27/09 08:20 PM
southwest Alabama
challenger73400 Offline OP
southwest Alabama
Great idea using a torque wrench , how do you get it in there with the sump on? , or am i missing something ........ ring spanner doubled up is all that fit in there.
I slide the tranny back about three inches. remember we are talking about the flex plate bolts holding the flex plate to the crank. I don't think you can get to them without sliding the tranny back some.
Re: What's the trick to keep flex plate bolts tight? [Re: bonefish] #481021
09/27/09 09:24 PM
09/27/09 09:24 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
oops ,yeh i knew that but was thinkin tq,
