Re: 340 or 360 Which one is a better build????
[Re: MoparforLife]
#480954
09/27/09 09:10 AM
09/27/09 09:10 AM
Posts: 533 North Dakota
440abody
North Dakota
360; just for the exact reasons that Moparforlife stated. They are far more plentiful, and in my opinion there are more parts available(stroker kits etc). Besides this also opens up an other possibility of using a Magnum motor vs the LA. Besides if you decide to build the car into a clone(tribute) a 360 visually will look identical to a 340.
73 Dart Swinger 440/727 8.75 w/3.55's 34 Ford 3w coupe with a soon to be 1958 392HEMI!
[Re: tee-john]
#480955
09/27/09 10:23 AM
09/27/09 10:23 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
the 340 versus 360 debate can go on endlessly, but it boils down to 'what stroke length' is best?' In this ongoing quest there is a recent development: When Ford recently designed a new V8 they used an even longer [edit] stroke than 3.58 inches and more similar to dodge V10 selection: http://www.themustangnews.com/carnews_09/0909-ford-6.2.v8-engine-137.htmdoes the engine care what the stroke is, or does it care what the ring friction is?
[Re: 360view]
#480956
09/27/09 10:35 AM
09/27/09 10:35 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
dollar for dollar spent, the 360 will ALWAYS make more power than the 340 when building a bare block.
--if you put the same cam, heads, intake and carb on the 340 and the 360, built the short blocks with stock cranks, rods and use pistons that give you an equal compression ratio between the 2, it's a no brainer...the 360 will win.
spend your money on a 360 stroker.
408 is the common stroker size, and can make very good power and still be streetable. lotta guys running them in Dakota's dipping into the 12s with a 4,000+lb truck, and still passing emissions with them.
**Photobucket sucks**
[Re: 70Cuda383]
#480957
09/27/09 11:00 AM
09/27/09 11:00 AM
Posts: 4,872 connecticut
pnypwr
connecticut
in stock form a 340s better, your 318 parts will bolt right on...eg oil pan, tans t. converter if its an forged crank 340, flywheel if its a std shift. you can go further with a 360 in the $$ dept because they are more plentiful. it really depends on what your looking to do
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd 74 gremlin x 360 65 mustang 347 70 coronet R/T 440 03 Mach 1
[Re: pnypwr]
#480958
09/27/09 11:07 AM
09/27/09 11:07 AM
Posts: 4,788 Holland MI Ottawa
2boltmain
Holland MI Ottawa
340s are great but c'mon, how many are out there REASONABLY priced? 340s made from 1968 to 1972-73. 360s made from 1972 to....2002
Keep old mopars alive.
[Re: 70Cuda383]
#480963
09/27/09 04:07 PM
09/27/09 04:07 PM
Posts: 28,611 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
If I had to redo the stoker again from scrath i would do good used 350 core 360 or new 340 race block to get the most cubes. As I have to much inside and on top the stock block Few Pics of 423SIX
[Re: 340SIX]
#480964
09/27/09 07:01 PM
09/27/09 07:01 PM
Posts: 17 N.E. Texas
pyrogen
N.E. Texas
in theory, more displacement provides more potential power.
I have to ask, Do you already have an engine to build or are you trying to determine which one to purchase to build?
2001 Dodge Dakota R/T reg cab - slow
1970 Dodge Dart Swinger /6 auto - slower
1988 Toyota Pick-up 4wd - slowest
[Re: dodgefarmer]
#480968
09/28/09 08:26 AM
09/28/09 08:26 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
start with a late model magnum 360. better heads, factory roller cam, you can build a hydraulic roller cammed motor much cheaper using factory parts.
[Re: dodgefarmer]
#480969
09/28/09 08:34 AM
09/28/09 08:34 AM
Posts: 79 montreal, quebec, canada
jimmy71demon
i am almost done building my 340 stroker. my 340 block was done so i had to find another one (i wanted to stay with the 340 block). it proved to be much harder than i thought to find a 340 block that was .020 over or less. (when its pretty much raining 360's) plus it was pricey. bang for ur buck ull prolly find a 360 out of a truck or a van or something for a hell of a lot cheaper than a 340. after that i dont c there being much difference in price for parts. p.s. im told my stroker with my mildly ported J heads and .488 lift comp cam should put out somewhere around 425-450 hp
Im goin fast Mom!
[Re: patrick]
#480970
09/28/09 10:00 AM
09/28/09 10:00 AM
Posts: 4,862 the frozen wastes...
Pale_Roader
Swears too much
Swears too much
Thats your answer right there. SO many improvements over the older stuff... and cheap cheap cheap! There was a thread on here a while back on how little it takes to 'make' that MP 300HP 360 crate engine out ov a junkyard roller 360. Even the 380HP one isn't far off if i remember right...
[Re: Pale_Roader]
#480971
09/28/09 10:16 AM
09/28/09 10:16 AM
RapidRobert
As said w stock strokes definitely a 360 vs a 340 for the reasons stated. With the 4" stroke there's only an 8 ci difference between the 2 (30 over 360 vs a 30 over 340) so I'd still go w the cheaper 360 block unless a person already has a 340 block on hand.
