transmission mount #480863
09/27/09 01:16 AM
09/27/09 01:16 AM
Greenville, WI
Big B Offline OP
Big B  Offline OP
Greenville, WI
My rubber transmission mount is shot on my 727
What should I replace it with?
A new rubber one or something else?
Re: transmission mount [Re: Big B] #480864
09/27/09 04:08 AM
09/27/09 04:08 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I used the poly mount kit from Summit.
Re: transmission mount [Re: Big B] #480865
09/27/09 07:33 AM
09/27/09 07:33 AM
MR_P_BODY Offline
MR_P_BODY  Offline
What is the rest of the mounting (front engine plate,
mid plate)?
Re: transmission mount [Re: MR_P_BODY] #480866
09/27/09 09:41 AM
09/27/09 09:41 AM
Greenville, WI
Big B Offline OP
Big B  Offline OP
Greenville, WI
I have a motor plate and a fore/aft limiter.
My rubber bushing is so shot that the transmission
is hitting the crossmember when I drive down a rough road
Re: transmission mount [Re: Big B] #480867
09/27/09 10:16 AM
09/27/09 10:16 AM
put back the rubber mount, just get a new one. no replacement for a rubber or poly trans. mount. i just replaced my original mount on my 63 plymouth.
Re: transmission mount [Re: Big B] #480868
09/27/09 11:54 AM
09/27/09 11:54 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I would use a new rubber one
Re: transmission mount [Re: MR_P_BODY] #480869
09/27/09 12:24 PM
09/27/09 12:24 PM
Greenville, WI
Big B Offline OP
Big B  Offline OP
Greenville, WI
Are the rubber bushings more forgiving then the poly ones?
Seems like the poly would be better, unless it puts more stress on the tailshaft.
If that is the case I will just get a rubber one
Cheaper anyways.
