493
11.2-1
ootb rpm heads, 84cc
.540 lift flat tappit hydraulic 250/263 @ .050
rpm intake
biggs stage 3 850 dp
MSD 6al, msb billit distributor & coil
2" TTIs
3" x-pipe, and ultra flows
727 fille with CRT stuff
RMVB
3800 PTC converter
Dana 60 with 3.73s
MT drag radials 325-50-15
Caltracs, split monos, Rancho 9 way, CE's up front
Timing is 16* initial, and 36* total, all in by 2200.
Jesse (BIGGS) built the carb for my engine.
81/89 jets
4.5 power valve primary, none on the secondary.
.037 primary/secondary shooters
50cc pump on primary, 30 on secondary
If I shift it at 5700 or so, seems like it's breaking up. Best at 5700 so far is 7.31 in the 1/8.
If I shift at 5000, seems strong, no sputtering or missing, and actually picked up a solid 10th, went 7.20.
Right now I have an Aeromotive oump, rated at 90 gph. Should I maybe step to to a 140 or 150 gph pump?
