Re: Let's talk 340 builds...... [Re: Chris2581] #480578
09/28/09 05:24 PM
09/28/09 05:24 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Using 4.10 gears and a 26" tire, will equate to 6040 RPM, driveshaft
speed and require 365 HP to get a 3200 lb. car to 114 MPH.
IIRC a T/A 3800 will tylically flash around 5000 RPM.
It is entirely doable but, cylinder head work and camshaft selection
will be critical.
Re: Let's talk 340 builds...... [Re: S/ST 3040] #480579
09/29/09 10:21 AM
09/29/09 10:21 AM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
will need a bit more gear than 4.10.
get trap rpm to 6500ish with gear/tire combo imo.
Re: Let's talk 340 builds...... [Re: theclutcher] #480580
09/29/09 10:29 AM
09/29/09 10:29 AM
S/ST 3040 Offline
S/ST 3040  Offline
I gave driveshaft speed as converter slippage is unknown.
5% slip would be 6360 engine RPM. I would expect no more than
5% from a T/A 3800. My T/A 4600 slipped less than 5% albeit, in
a lighter car with more gear and RPM.
Re: Let's talk 340 builds...... [Re: S/ST 3040] #480581
09/29/09 11:27 AM
09/29/09 11:27 AM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
keep forgetting about your guys converter slip.
think a 4.30 would be too steep?
Re: Let's talk 340 builds...... [Re: theclutcher] #480582
09/29/09 11:35 AM
09/29/09 11:35 AM
S/ST 3040 Offline
S/ST 3040  Offline
NO.....not too steep at all but 4.10 is his self-imposed gear.
Re: Let's talk 340 builds...... [Re: S/ST 3040] #480583
09/29/09 11:48 AM
09/29/09 11:48 AM
S/ST 3040 Offline
S/ST 3040  Offline
Here's the dyno sheet from last year's EM 345"
10.4:1 flat tappet, pump gas
Obviously the INDY 360-2 heads are over-kill for 365 HP
but, at least it shows a 340 is more than capable of
meeting his goals with his 4.10 gear. (HP @ 6000)
Re: Let's talk 340 builds...... [Re: S/ST 3040] #480584
09/29/09 12:02 PM
09/29/09 12:02 PM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
A well done set of 894's, a good solid lifter, and around 10.5 CR should get you where you want to be. It would not hurt to put more screw to it down the road.
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Re: Let's talk 340 builds...... [Re: sixpackbee] #480585
09/29/09 12:11 PM
09/29/09 12:11 PM
S/ST 3040 Offline
S/ST 3040  Offline
There's no way an OEM will even come close to making any power.
Re: Let's talk 340 builds...... [Re: S/ST 3040] #480586
09/29/09 12:24 PM
09/29/09 12:24 PM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
So say you.
1959 Bugeye Sprite
1971 MG Midget
