Re: Dominator tuners, what's going on here?
[Re: Quicktree]
#479706
09/25/09 10:33 PM
09/25/09 10:33 PM
check to see if the secondaries are sticking open too. some of those carbs had internal linkage probelems. has this carb been on for awhile, or new to the combo?
[Re: Quicktree]
#479707
09/25/09 10:37 PM
09/25/09 10:37 PM
Posts: 2,527 PA
moparacer
PA
The machining of the transfer slots is sometimes off.
You might still have too much exposed even though the throttle plates are completely closed.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: 602heavy]
#479709
09/25/09 10:46 PM
09/25/09 10:46 PM
Posts: 11,739 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
If it's still running, it's getting air from somewhere. Verify that the throttle blades are actually closed. If they are, there's an air leak somewhere. I'm betting the throttle blades aren't closed, since there has to be air moving through the carb to pull fuel from the idle circuits.
Post deleted by Defbob
#479710
09/25/09 10:47 PM
09/25/09 10:47 PM
#479711
09/25/09 10:55 PM
09/25/09 10:55 PM
Flashback, February 2002!
absolutely!!! that brings back fond memories of you, me and Gary (unlawfl) working on your Duster. we all had a great time. i've worked on several since then too with similar problems.
#479712
09/26/09 08:30 AM
09/26/09 08:30 AM
Posts: 762 Southington Ct.
turbobitt
Southington Ct.
I noticed on some carbs that you have to back out all the way on the idle screws and then loosen the screws that hold the butterfly's in place to allow themselves to align in the bore and close properly. You can uasually detect this by forcing them close with a little more than spring pressure. If the idle goes down, than the throttle plate"butterfly's" are binding near the closed position. Allan G.
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
#479714
09/26/09 11:18 AM
09/26/09 11:18 AM
Posts: 2,155 Tucson, Arizona
clonestocker
Tucson, Arizona
Dave, You did fix it right? It's still in the box. One of these days. matt
[img] [/img]
