Don't like spraybar oiling too much! ? #479500
09/25/09 05:37 PM
09/25/09 05:37 PM
Colorado,U.S.A
4404dart Offline OP
4404dart  Offline OP
Colorado,U.S.A
I'd like to get rid of the spraybar oiling on the 572-13 heads I have. It's a Indy Maxx alum block, with no holes from the oil galley to the lifters currently in the block, 572 heads and Jesel rockers. The rocker adjusting screw has a hole all the way thru it, and there is no hole in the rocker body from the screw to the bearing. The Crower lifters are set up for pushrod oiling, the Smith pushrods are solid. What all do I need to oil thru the pushrod? Thanks,Dave.
Re: Don't like spraybar oiling too much! ? [Re: 4404dart] #479501
09/25/09 05:47 PM
09/25/09 05:47 PM
IN
Dartman928 Offline
Dartman928  Offline
IN
Dave,
Get ahold of Chuck or Pete at Best Machine as I have a 572 with 572-13 heads and we went with pushrod oiling. I have jesel rockers and trend push rods and isky red zone rollers.
That the best advice I can give
Re: Don't like spraybar oiling too much! ? [Re: Dartman928] #479502
09/25/09 06:27 PM
09/25/09 06:27 PM
Colorado,U.S.A
4404dart Offline OP
4404dart  Offline OP
Colorado,U.S.A
Dave,
Sounds like good advice,thanks!
Re: Don't like spraybar oiling too much! ? [Re: 4404dart] #479503
09/25/09 07:11 PM
09/25/09 07:11 PM
Illinois
CRE2004 Offline
super gas
CRE2004  Offline
super gas
Illinois
You need to pull it apart and rifle drill the oil galleys if you want to pushrod oil. What problem are you having with the spray bars?
Re: Don't like spraybar oiling too much! ? [Re: CRE2004] #479504
09/25/09 07:20 PM
09/25/09 07:20 PM
Colorado,U.S.A
4404dart Offline OP
4404dart  Offline OP
Colorado,U.S.A
A couple of burnt pushrods. I drilled the holes in the tubes in the valve covers bigger and it helped, and was even going to go bigger, and run a return line from the head to the pan, but I'm not confident in the system? I like to drive it once in awhile on the street, but I don't trust it so it sits till race day. Any suggestions are welcome. Thanks.
Re: Don't like spraybar oiling too much! ? [Re: 4404dart] #479505
09/25/09 07:28 PM
09/25/09 07:28 PM
Hemiroid Offline
Hemiroid  Offline
With ball/ball pushrods you really need pushrod oiling. The cup on a cup/ball pushrod acts as a oil catcher and small reservoir. It's hard for the rocker end of a ball/ball pushrod to catch and keep much splash fed oil IMO.
EDIT: Ball/ball systems don't "need" push rod oiling to work, I've personally just had better luck with cup style rods with spray bars. I know guys using ball/ball rods without pushrod oiling and not having problems so who knows. Make sure the oil spray is pointed in the right direction as well
Re: Don't like spraybar oiling too much! ? [Re: 4404dart] #479506
09/25/09 07:28 PM
09/25/09 07:28 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
i use a spray bar system,with 572-13,s on the street.i use k motion 1000h springs with 825# on the nose.havent had any problems.i like how the spray bars oil the valve springs. helps them last in a street car.
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: Don't like spraybar oiling too much! ? [Re: 4404dart] #479507
09/25/09 07:49 PM
09/25/09 07:49 PM
Illinois
CRE2004 Offline
super gas
CRE2004  Offline
super gas
Illinois
You've probably got enough oil coming up top, it's just not getting where it needs to go. It's tougher to do with ball pushrods and the cup style adjusters, but it can be done. Are the spraybar feeds restricted at all?
Re: Don't like spraybar oiling too much! ? [Re: 4404dart] #479508
09/25/09 08:26 PM
09/25/09 08:26 PM
IN
Dartman928 Offline
Dartman928  Offline
IN
Wanted to let you know I drive mine on the street with no problems
Please pm me if you need any help.
Thank you
Re: Don't like spraybar oiling too much! ? [Re: Dartman928] #479509
09/25/09 10:48 PM
09/25/09 10:48 PM
UK
602heavy Offline
602heavy  Offline
UK
I drilled the rocker arm to valve adj , also made sure the spray bar oil holes were facing/spraying on to the valve covers , this will make sure the oil sprays directly onto the adj/PR , i agree the ball/ball is not a good idea as mentioned earlier , i was forever pulling the valve covers to find a couple of scorched rods , all is good now.
Re: Don't like spraybar oiling too much! ? [Re: CRE2004] #479510
09/25/09 11:20 PM
09/25/09 11:20 PM
Colorado,U.S.A
4404dart Offline OP
4404dart  Offline OP
Colorado,U.S.A
I think so, the fitting in the valve cover has a pretty small openning, .030 maybe?
Re: Don't like spraybar oiling too much! ? [Re: 602heavy] #479511
09/25/09 11:39 PM
09/25/09 11:39 PM
Colorado,U.S.A
4404dart Offline OP
4404dart  Offline OP
Colorado,U.S.A
So you had the spray bars spraying to the back of the valve cover, or the intake side? Where did you drill exactly? Just trying to picture it, thanks for the input.
Re: Don't like spraybar oiling too much! ? [Re: 4404dart] #479512
09/25/09 11:52 PM
09/25/09 11:52 PM
Salisbury North Carolina
8secDart Offline
8secDart  Offline
How much vac on the pump?Does it have a baffle in the valve cover?I run the pump to the valIey on spray bar oiling.I have run the spray bars for years and years on the street with no problems.I do use a one piece pushrods.My Hemi would eat Smith brothers pushrods,I went with CV one piece and no more problems.The one piece has a smaller end and I think it helps to oil better.Lenny
Re: Don't like spraybar oiling too much! ? [Re: 8secDart] #479513
09/26/09 01:13 AM
09/26/09 01:13 AM
Eagleville Tn.
rtstreet Offline
rtstreet  Offline
Eagleville Tn.
had spray bars on the 477 with no problems, think i had a .050 hole at the line conection and drilled my on holes in the tubbing (brake line)
Re: Don't like spraybar oiling too much! ? [Re: 4404dart] #479514
09/26/09 01:25 AM
09/26/09 01:25 AM
AndyF Offline
AndyF  Offline
Pushrod oiling is a more positive way to get the oil to the end of the pushrod but in your case it is going to cost you a ton of money to fix that block.
I'd recommend taking the restriction out of the valve cover and running it full bore to see how it works. Then restrict back down from there if you have too much oil. Also, make sure the holes in the spray bar are lined up with the rocker arms. I toasted the first set of pushrods when I put on the Indy valve covers because things weren't lined up correctly and because the line was restricted.
There weren't any instructions in the box and I wasn't smart enough to sit there and figure it all out myself. I just assumed the stuff would work right out of the box but that wasn't very smart of me.
Re: Don't like spraybar oiling too much! ? [Re: 8secDart] #479515
09/26/09 10:37 AM
09/26/09 10:37 AM
Colorado,U.S.A
4404dart Offline OP
4404dart  Offline OP
Colorado,U.S.A
Vac on the pump is about 7 at idle then 13 full throttle. It does have a baffle now, because the fitting is over # 1 and that exhaust was the first one to burn, so I baffled it, and enlarged the holes on #'s 1 and 2.Thanks for the info.
Re: Don't like spraybar oiling too much! ? [Re: rtstreet] #479516
09/26/09 10:38 AM
09/26/09 10:38 AM
Colorado,U.S.A
4404dart Offline OP
4404dart  Offline OP
Colorado,U.S.A
This may be a good idea, Thanks!
Re: Don't like spraybar oiling too much! ? [Re: AndyF] #479517
09/26/09 10:45 AM
09/26/09 10:45 AM
Colorado,U.S.A
4404dart Offline OP
4404dart  Offline OP
Colorado,U.S.A
I bought this setup used, but new or used, these things are sometimes trial and error, luckilly the error part isn't too bad yet, just a few burnt pushrods. You were smart enough to figure it out, I hope I am too.
Thanks for the input, I think what I'll do is send more oil to the rockers like you said, and I already have the back of the head drilled and tapped, so I can add a fitting and drain the oil to the pan if needed. So drilling the block, bushing the lifter bores, and fixing the rockers would be pretty pricey? Thanks.
Re: Don't like spraybar oiling too much! ? [Re: 4404dart] #479518
09/26/09 11:40 AM
09/26/09 11:40 AM
SE Michigan
TS3303 Offline
TS3303  Offline
SE Michigan
The problem with spray bars is you can't see where the oil is going with the VC's on. Cut a window in the top leaving a 1/2" flange around the outside and make a billet cover. Then you can take it off and prime it by hand to see were the oil is aimed.
Re: Don't like spraybar oiling too much! ? [Re: 4404dart] #479519
09/26/09 11:46 AM
09/26/09 11:46 AM
Sherwood park, Alberta.
go green Offline
go green  Offline
This is what I did. No problems.
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
