Re: NO BRAKES
[Re: 340RICK]
#479311
09/25/09 03:37 PM
09/25/09 03:37 PM
Quicktree
Put it in Park.
didn't read the intructions did you? no thats not it.
Post deleted by Defbob
[Re: Quicktree]
#479312
09/25/09 03:39 PM
09/25/09 03:39 PM
Re: NO BRAKES
#479313
09/25/09 03:40 PM
09/25/09 03:40 PM
Quicktree
Chute, I don't know...
no chute
Re: NO BRAKES
[Re: Quicktree]
#479315
09/25/09 03:41 PM
09/25/09 03:41 PM
Quicktree
Re: NO BRAKES
[Re: Quicktree]
#479316
09/25/09 03:43 PM
09/25/09 03:43 PM
Posts: 4,501 Gainesville,FL
goldmember
Gainesville,FL
Close your eyes and turn hard to the wall? Pull the hood release to act as a front mounted chute? Open the door and drag foot? I can think of some more that may be less risky.
Re: NO BRAKES
[Re: Quicktree]
#479318
09/25/09 03:45 PM
09/25/09 03:45 PM
dartman366
Mt. Vernon, Ohio
go for the guard rail and scrub off speed after clicking off the motor
Re: NO BRAKES
[Re: weedlayer]
#479321
09/25/09 03:46 PM
09/25/09 03:46 PM
Quicktree
I think I know, but the real question is: will you get another movie for this??
very possible ask me if I care. hopefully this may save somebodies life or car.
Re: NO BRAKES
[Re: dc426]
#479323
09/25/09 03:48 PM
09/25/09 03:48 PM
Quicktree
I would say if you have a low band apply VB jam it in low or second (if not LBA). But after that all you can do is shut the car off in gear. DC
wrong and wrong, thats not yes or no
Re: NO BRAKES
[Re: 65dragnet]
#479332
09/25/09 04:25 PM
09/25/09 04:25 PM
Posts: 7,131 Amarillo, Texas
BBR
Amarillo, Texas
Perform in "inverted Rockford".
Crank the wheel and jam it in reverse!
Ok Tony-Wan Kenobi, what's the answer?
Drag Week 2011 - 77th place - DD Drag Week 2012 - 2nd place SRBB N/A Drag Week 2014 - Kapooya RMRW 2018 RMRW 2020
Re: NO BRAKES
[Re: John_Kunkel]
#479333
09/25/09 04:27 PM
09/25/09 04:27 PM
Quicktree
Put it in Reverse.
I knew one of you tranny guys would know. this is a last resort after down shifting and what ever you can do scrub off speed hasn't worked. you use reverse to lock up the rear wheels. you put it in reverse and pull it out and repeat untill the car stops. sometimes you don't have a lot of time so you have to think quiclky. this will stop the car and I would rather do this than go off the end of the track.
Re: NO BRAKES
[Re: Quicktree]
#479337
09/25/09 04:30 PM
09/25/09 04:30 PM
Posts: 716 Indiana
65dragnet
Indiana
So this will work with a transbrake car where reverse is neutral via the transbrake button ?
E. Williams 65 Coronet 500 3400lbs w/d, 446, Indy EZ'S, A&A transbrake,Comp 650 lift cam, 6.50 @ 105 mph 1/8th 10.25 @ 130mph 1/4
Re: NO BRAKES
[Re: camastomcat]
#479338
09/25/09 04:31 PM
09/25/09 04:31 PM
Quicktree
Dump laundry, click off motor, downshift to first, and hit transbreak.That's what I would do
you never turn the motor off, you would be done. only way I would click it off is if the throttle stuck.
Re: NO BRAKES
[Re: 65dragnet]
#479339
09/25/09 04:36 PM
09/25/09 04:36 PM
Quicktree
I think you would have to mash the button.
Re: NO BRAKES
[Re: 65dragnet]
#479341
09/25/09 04:42 PM
09/25/09 04:42 PM
Quicktree
well, yes ! Thanks good info ! Hope I never have to try it !
I did try it once by accident, thats how I knew the answer. many many years ago I was driving and very low on gas. coming over a bridge I decided to put it in neautral to save some gas. oops it went into reverse at 60 mph locked up the rear wheels and scared the crap out of me snatched in back down and went on my way.
Re: NO BRAKES
[Re: John_Kunkel]
#479345
09/25/09 04:49 PM
09/25/09 04:49 PM
Posts: 74,978 U.S.S.A.
JohnRR
U.S.S.A.
Put it in Reverse.
that tends to rip the outer race of the overruuning clutch out of the case
Re: NO BRAKES
[Re: camastomcat]
#479346
09/25/09 04:49 PM
09/25/09 04:49 PM
Quicktree
The pump is still turning and you wouldn't be done, and by the way, what makes you the expert? Have you ever had it happen? I have!
looknumnuts I was just trying to save somebodies butt. no expert here on anything. just some info I shared.
Re: NO BRAKES
[Re: 65dragnet]
#479347
09/25/09 04:50 PM
09/25/09 04:50 PM
JohnRR
U.S.S.A.
emergency or parking brakes are not legal on race cars.
but but .....
Re: NO BRAKES
[Re: camastomcat]
#479348
09/25/09 04:53 PM
09/25/09 04:53 PM
JohnRR
U.S.S.A.
How is the pump still turning whe nthe engine is OFF
Re: NO BRAKES
[Re: goldmember]
#479350
09/25/09 04:54 PM
09/25/09 04:54 PM
Quicktree
good to see you guys the other night. we will be back out saturday. it will go down the track this time
Re: NO BRAKES
[Re: Quicktree]
#479351
09/25/09 04:57 PM
09/25/09 04:57 PM
Posts: 2,128 Salt Lake City
camastomcat
Salt Lake City
Then tell them what they can use, hitting the wall to scrub speed might be the only way to help yourself if you are in a car with out a t/break and especially at speed. The reverse trick will only work if you are going slow enough, and if it breaks a driveshaft or the trans locks and blows, you're screwed. I an older, slower style car that has an e-break (street) you can slow down some with that. I really don't have the answer and don't think there really is one. And when it happened to me, I didn't think fast enough and hit the wall. So, if there really is a way to slow safely, I'd like to hear it. Otherwise, I'm going with my plan B. Oh.........and it's Mr. Numnuts to you!
Re: NO BRAKES
[Re: JohnRR]
#479352
09/25/09 04:58 PM
09/25/09 04:58 PM
Posts: 2,872 CheddarHead till October
weedlayer
that is what I was wondering. been a long time since the rear wheels turned the pump. ala tow a Mopar auto to start
Re: NO BRAKES
[Re: weedlayer]
#479353
09/25/09 05:03 PM
09/25/09 05:03 PM
Quicktree
not a tranny guy but it may turn a little at high speed but I doubt it would be enough to do anything. and for Mr numnuts this was for us evryday brackets racers with no chutes, no transbrakes, and for those that don't want to scrape the wall if they can help it. it's a better method than the alternative imo.
Re: NO BRAKES
[Re: Quicktree]
#479355
09/25/09 05:32 PM
09/25/09 05:32 PM
Posts: 2,475 SW Ohio
cgall
SW Ohio
When it happened to me, I was at a track I had never raced at before, so I had made a trip to the top end and made a mental note as to what I would do in such a situation. The track had a rather short shutdown area, a long sand trap, then a serious dropoff into a valley. I noted that the sand led to a dirt access road on the left side. So I thought if I had problems, I would steer to the left.
After 4 runs Friday and 6 runs Saturday, I made my first run Sunday, crossed the stripe at 127 MPH, reached for the brake pedal...and it was up against the steering column with the prop rod against the firewall. A feeling of terror came over me, but I knew right away that I would go left through the sand.
I coasted a couple hunded feet, then shifted into 2nd, that scrubbed off a bunch of speed, then I shifted into 1st, forgetting that the trans would freewheel with my older valve body. The motor died, I hit the sand, then turned to the left. The car made 1/2 a spin and stopped.
Never did I consider shifting into reverse. I have heard of this being done with street cars, but I think if you do this with a 9 or 10-second car, the back end will come around and you will roll it.
Re: NO BRAKES
[Re: cgall]
#479356
09/25/09 05:37 PM
09/25/09 05:37 PM
Quicktree
good points thats why you pull it out. believe me I wouldn't want to try this but I sure would before going off through the woods or something. this is just a topic for thought. you have to ready for anything when racing.
Re: NO BRAKES
[Re: Quicktree]
#479357
09/25/09 05:44 PM
09/25/09 05:44 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
It was a stock eliminator driver and his brake pedal pushrod fell out.(GM car)Bad thing is if the side window in the car had not blown out,he might not be here today.
Re: NO BRAKES
[Re: B G Racing]
#479359
09/25/09 05:52 PM
09/25/09 05:52 PM
Quicktree
If like you say he traveled a mile before ending up in the lake why not just shut down the engine in gear and let the distance of the shut down bring you to a slow controlled stop or controlable speed?I have seen guys blow an engine at the stripe and leave the car in gear,not touch the brakes because of oil and get it slowed enough to exit the track to the return road,even using the resistance of a rearend spool to even slow it more while exiting and steering on the return road to a safe stop.Locking slicks up at speed isn't my idea of fun.
something strange must have happened on that run. locking slicks up wont be fun but being upside down in a lake full of water strapped in a race car would probably be worse don't you think?
Re: NO BRAKES
[Re: Blown71X]
#479361
09/25/09 06:29 PM
09/25/09 06:29 PM
Quicktree
I can`t stand it.....This has to be simply the most idiotic thing I have seen posted on this forum, tossing a car in reverse with any kind of drag race tire at, lets just say 100 mph is not going to end well, and before you say anything, YES I personally have had it happen due to a junk shifter gate, The only thing that kept that car from hitting anything was pure luck. Anybody that thinks they can get it in and out of gear fast enough to avoid the obvious while still reeling from the shock of not having brakes plus just the initial "hit" from trans and driveline parts trying to cry foul, Try it...Prove me wrong but Please get video and hopefully nobody else is close.
I`ll choose scrubbing speed off on the wall, thank you.
Rick
get you some wall then
Re: NO BRAKES
[Re: Blown71X]
#479362
09/25/09 06:36 PM
09/25/09 06:36 PM
Quicktree
Rick
and Mr Rick the only idiotic thing would be ending up dead with no options.
Re: NO BRAKES
[Re: 65dragnet]
#479364
09/25/09 06:42 PM
09/25/09 06:42 PM
Posts: 7,348 Mt.Vernon ,Ohio
VernMotor
Mt.Vernon ,Ohio
SAY What ???? My has a emergeny brake and that is how I would stop it !
Re: NO BRAKES
[Re: John_Kunkel]
#479366
09/25/09 06:44 PM
09/25/09 06:44 PM
Quicktree
Put it in Reverse.
How? The band stops the rear drum which stops the sprag inner race.
A local Pro Gas racer once stuffed it in Reverse at 130+ mph, (trying to hit Neutral so he could read the plugs) brought the trans to me for a look/see and I couldn't find any damage.
so it sounds like he survived it with little damage so doesn't sound that idiotic now does it? it is possible if you have a little driving skill and think fast. not saying I could it's just an option
Re: NO BRAKES
[Re: Quicktree]
#479367
09/25/09 06:44 PM
09/25/09 06:44 PM
i lost my brakes in my 63 plymouth 7 years ago at island dragway which has a little shutdown area, i crossed the traps at 130 mph, went for the brakes and no go. first i said "damn this is gonna hurt", then i decided to let off of gass pedal, let the car start slowing down on its own a little and then at around 80 mph, down shifted to 2nd, that go me down to around 55 mph, i then clicked off motor and headed for the grass area, which i then slid it sideways a little and it then slowed down to a stand still. never would i want to drop it in reverse, but i guess pushing my dash trans. buttons to reverse might be an option in the future.
Re: NO BRAKES
[Re: cgall]
#479369
09/25/09 06:52 PM
09/25/09 06:52 PM
Quicktree
My point is to know your track. If that guy knew of the lake, he would have tried to spin the car out or turn away.
The two tracks I have raced at mostly over the years I know well and would have a strategy for brake failure. Edgewater has a pretty long shutdown and a sand (mostly mud) trap, then a few trees at the edge of the Great Miami River. There were a few deaths years ago when fast cars went into the river. I have talked to bracket racers that lost brakes there, they were able to make the turn onto the return road (or into the adjacent field) without turning over.
Tri-State Dragway is similar, although they run S/P and Pro on 1/8th mile now. Go straight and you will hit 100 ft. of corn, then the river. Turn left and you can try to make the return road or more corn and then trees.
I believe that both Indy and Columbus have the large catch nets installed now.
all good points, when my son was racing thats the first thing we did at new tracks. drove to the top end and talked about ways out. and gville did have a catch net, it failed...
Re: NO BRAKES
[Re: Blown71X]
#479371
09/25/09 06:55 PM
09/25/09 06:55 PM
Quicktree
What ever you think, there are always options...reverse at triple digit speeds is NOT one.
sure it is, tell me how many tracks have walls past the finish line? so you are saying you would rather cut down trees than to spin out and roll? I say have it.
Re: NO BRAKES
[Re: SomeCarGuy]
#479372
09/25/09 07:01 PM
09/25/09 07:01 PM
Quicktree
There was a guy about 5-6 years ago that was running a pretty hot Vette, ran like a high 4 eighth mile, was running at our local track.
The car came off strong and broke traction around the 60' mark, he lifted and then nailed it again. I recall thinking that was pretty dumb at the moment. It sure was.
The throttle hung and when he got to the stripe he pulled the chutes and they just sort of popped open and collapsed in a half second or so.
Instead of just hitting the kill switch, he simply held on as the car ran about 1/4 mile under full throttle. He hit the trees at the end right after he minced the hay bails and such. He lived but was air lifted. Never really heard anything after that. The Vette was hauled out of the woods in tiny pieces.
Still not sure why he didn't at least kill that motor. Maybe he was so spooked he froze up.
Every older racer at the track was shaking their head about how an experienced guy would try to get back on a busted run.
did he get knocked out? very possible.
Re: NO BRAKES
[Re: forphorty]
#479374
09/25/09 07:56 PM
09/25/09 07:56 PM
Quicktree
Years ago i bought a 72 Challenger as a roller and dropped my street 440 and 727 into it. Unbeknownst to me , the car had a power brake master cylinder pushrod with a manual mc. There was no brake light switch either, so nothing to keep the rod from coming out,which it did on my first pass. What a surprise to find the brake pedal up against the bottom of the dash when it came time to stop. A downshift to 2nd didn't help much, so i went to reverse. I thought i could just bump reverse and put it back into neutral. Locked up the slicks and pitched the car sideways pretty good. Instantly. Can't say i wouldn't do it again but it would probably be a last resort. Im sure i was well below 100 mph when i thought to put it into reverse. Hate to think what would happen at high speed.
great story, and proves again that it could work under extreme conditions. you stoped the car and didn't crash. yes it's last resort but a viable option none the less. and look how many people didn't know it was an option.!!!!!!!!
Re: NO BRAKES
[Re: camastomcat]
#479375
09/25/09 07:57 PM
09/25/09 07:57 PM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
downshift to first, and hit transbrake. That's what I would do
Well, since this happened to my car. I kind of knew what to do, (after the fact.) Since Billy D always shut the motor off after the stripe, he had no way of doing the correct thing. (that won't happen again)
If the engine is running ..Yes you can downshift into low gear, (powerglide) and start tapping the trans brake button. It would most likely damage the trans, but the damage to my car, is much, much worse that a broken powerglide.. Just my from already having gone through it..
Chris..
Re: NO BRAKES
[Re: Chris'sBarracuda]
#479378
09/25/09 08:11 PM
09/25/09 08:11 PM
Quicktree
Chris..
exactly
Re: NO BRAKES
[Re: Quicktree]
#479379
09/25/09 08:53 PM
09/25/09 08:53 PM
most mopar bracket guys run a torqueflite with a no low band apply trans. so going into 1st will only make you free wheel.
Re: NO BRAKES
[Re: Quicktree]
#479381
09/26/09 12:18 AM
09/26/09 12:18 AM
Posts: 10,201 Someplace you aren't
SomeCarGuy
Would have had to happen after the chutes came out at the eighth mile.
He was out after the trees no doubt.
Re: NO BRAKES
[Re: SomeCarGuy]
#479382
09/26/09 12:28 AM
09/26/09 12:28 AM
Posts: 34,880 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
I'm always just a bit suprised on the people that want to go FAST 1st, slow down 2nd ..
More than once , I've had someone come up to me and say
"wow, the shut down area is short"
Did you go look at the end before you belted in ?
Ahh, gee ..No I didn't ?
Kidding me right ..No man, I didn't ..
You dumb chit ..
I have a nice brakes and a chute and think about what if each and every pass ..
Sadly few do ..
i have a friend with a old tea cup master cylinder , Hemi car goes low , low 10's big old heavy b-body ..seen it go 10.19
thinks its cool , "nostalgic"
Be real cool flying off the end at a buck 135
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: NO BRAKES
[Re: bigdad]
#479383
09/26/09 02:53 AM
09/26/09 02:53 AM
Quicktree
You dumb chit ..
Sadly few do ..
yep that was the whole point for the thread, to make people think. but some find it idiotic
Re: NO BRAKES
[Re: John_Kunkel]
#479385
09/26/09 08:21 AM
09/26/09 08:21 AM
JohnRR
U.S.S.A.
Put it in Reverse.
Don't know John , but when I was 17 or 18 I did it in my moms 72 fury doing about 45mph , the rears locked and the engine stalled. A few years later when we junked the car I saved the trans , took it apart and when I flipped it bellhousing side down the outer race and a piece of the case fell on the floor ...
Re: NO BRAKES
[Re: B G Racing]
#479386
09/26/09 08:36 AM
09/26/09 08:36 AM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
especially at gainsville....hell, I went through the traps at 160+ on seven cylinders, missed the second exit and took forever to get to the end of the track...that sucker is loooong
I bet If I never hit the brakes it wouldn't have coasted to the end
Now I know Gainsville is an exception....some tracks it could get nasty quick
Rickster
Re: NO BRAKES
[Re: 72Challenger]
#479387
09/26/09 08:53 AM
09/26/09 08:53 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I have lost my brakes once... lucky it was 1/8 racing. I was doing 120, hit the pedal and thought it was strange the pedal went so far down... hit it again and it went to the floor... fortunately I could zig zag to scrub off speed, down shift to second and at the last turn off I was doing about 30 and spun it out on the turn off. I have a chute BUT being 1/8 mile I didnt pull the safety pin.... now I never put the pin back in
Re: NO BRAKES
[Re: MR_P_BODY]
#479388
09/26/09 01:58 PM
09/26/09 01:58 PM
Posts: 7,506 Az
Crizila
Az
I can make all of the above scenerios not apply. Was racing my 63 Plymouth Max wedge car in 65 when I missed the 2-3 shift ( at the time I was running a hemi 4-spd )and had a major clutch explosion. Took out the bell-housing ( oil pan fell down on to the center link ), most of the flywheel, Brake line ( single master in 63 ), blew out the right front tire, took out the guys windshield I was racing with ( we were side by side when it blew). Coasted through the lights at 78 mph. Fortunately, the track I was at ( US30 in Indiana )had a long shut down area with lots of tall grass on ether side. Got the car stopped just as the ambulance pulled along side. I stepped out unscratched. Car wasn't so lucky. I was supprised at how many clutch springs were sitting on top of my cross-ram manifold. It wasn't pretty.
Fastest 300
Re: NO BRAKES
[Re: CokeBottleKid]
#479395
09/26/09 09:26 PM
09/26/09 09:26 PM
Quicktree
Sooo what do you do with a Lenco with 3 sprags in it and no way to get into reverse at speed?
you have no worries it will never make it out of the garage
Re: NO BRAKES
[Re: Quicktree]
#479396
09/27/09 12:35 AM
09/27/09 12:35 AM
Posts: 8,180 Detroit, MI
CokeBottleKid
Detroit, MI
With comments like those you'd better know how to stop a car with no brakes... I might have to make an un-announced visit to the pits next time you're running.
Re: NO BRAKES
[Re: GTSDave]
#479399
09/27/09 08:24 AM
09/27/09 08:24 AM
Chris2581
Jacksonville, FL
I shifted in reverse on my very first car I owned as I put a shift kit in it and was running it thru the gears down the road.Rear locked up,but the car was fine,no trans damage.318/904 in a Duster.
