Will a 440 fluid damper work on a race built hemi?
#479066
09/25/09 09:30 AM
09/25/09 09:30 AM
Posts: 2,103 East Coast, NJ
fig426
East Coast, NJ
A friend of mine has a fluid damper (fliudampr) off a 440. I'm building a 528 hemi. Will the damper work on the hemi?
Chris from New Jersey
Re: Will a 440 fluid damper work on a race built hemi?
[Re: fig426]
#479071
09/25/09 07:55 PM
09/25/09 07:55 PM
Posts: 2,503 Illinois
CRE2004
super gas
super gas
Illinois
IMHO, those dampers are better suited to low rpm steady state industrial applications. I won't run them.
[Re: CRE2004]
#479072
09/25/09 07:59 PM
09/25/09 07:59 PM
, nothing but bearing problems when i ran one, my bearings after 60 passes were all smeared, i raced the beaerings, same thing again. i went to a ATI super balancer and no more wiped bearings. they are junk for any decent HP motor.
#479073
09/25/09 09:28 PM
09/25/09 09:28 PM
Posts: 644 Minnesota
Barnstorm
Minnesota
Yeah....My engine builder says the're no good. ATI here. Motor happy.
The little old lady from Pasadena is back!
[Re: Thumperdart]
#479075
09/25/09 10:58 PM
09/25/09 10:58 PM
Then my junk low powered 7500+ rpm motor must be the exception or maybe I got a good one.
it's easier to just blame the damper.
[Re: AndyF]
#479078
09/26/09 08:38 AM
09/26/09 08:38 AM
Posts: 1,169 Virginia Beach, VA
Old School
Virginia Beach, VA
i have one on every one of my motors. some more than 15 years.......
68 cuda formula S 588" bb 5sp 70 CUDA CONVERT 500" 5SP (SUBLIME) 70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
[Re: Cab_Burge]
#479079
09/26/09 10:38 AM
09/26/09 10:38 AM
Quicktree
the complaints I have heard on the Fluid Dampener are all from the northeast states where it gets cold, it seems that the fluid in the Fluid Dampeners turns to jelly in the cold and does not keep in the liquid form like it is normally, which makes the motor go out of balance and does cuase damages. A lot of the 500 C.I.Pro Stockers ran them for years They didn't race in the cold either
guess you didn't read eddie's story of 5 or so broken cranks in circle track motors down here. swapped it out with an ATI and no more broken cranks.
[Re: StrokerAspen]
#479081
09/26/09 12:07 PM
09/26/09 12:07 PM
If the engine is balanced properly, why would you ever need a fluid dampener?
every engine needs some sort of dampener to dampen harmonics, which all engines have. it's really just a question of which "type" of dampener to use.
Quicktree,i remember reading one of Eddie's posts with something to that effect. keep in mind those are mid to high to mid to high to mid, etc, etc. high rpm SBC motors with the tiny little snouts on them. IMO, that's not a good environment for any fluid type dampener, regardless of brand. also note that fluid dampers are much heavier typically than the ATI, Romac, BHJ, etc. etc. that heavy rotational inertia could have something to do with the problem Eddie had. those dampers aren't normally my first choice, but so far, every one i've used (probably over 100 of them) has worked just fine.
#479082
09/26/09 12:22 PM
09/26/09 12:22 PM
Posts: 10,225 Someplace you aren't
SomeCarGuy
How do you all feel about Romac brand?
I want my fair share
[Re: fig426]
#479084
09/26/09 01:22 PM
09/26/09 01:22 PM
Posts: 1,131 Thigh-Gap Junction
New user name, Same old jerk!
Thigh-Gap Junction
A couple of points: The fluid in a Fluidamper isn't a fluid, it's a gel. The damper is for torsional vibrations, it has nothing to do with the balance of the motor. Elastic type dampers will work best at a certain frequency of vibration and the effect will diminish the farther you get from that number. I expect that the viscous (fluid) type dampers will be effective over a wider range of engine speeds.
