7260 -1350 conversion u-joint #478619
09/24/09 08:40 PM
09/24/09 08:40 PM
Maryland
dduster73 Offline OP
Maryland
Does anyone know if there is a conversion u-joint for a 7260-1350 u-joint. I'm trying to hold off on buying another driveshaft right now.I have a 7260 drive shaft ,but I am putting a Dana60 in the car and the yoke is a 1350.Just want to get the car together this weekend if possible.Anyone know a part # and what auto parts store I can one from.Thanks, dduster73
Re: 7260 -1350 conversion u-joint [Re: dduster73] #478620
09/24/09 09:46 PM
09/24/09 09:46 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
I'm sure NAPA can get the correct Spicer conversion u-joint for you.
Do you have a local driveshaft shop? I went to one when I needed a conversion u-joint and was in and out within ten minutes.
Re: 7260 -1350 conversion u-joint [Re: dduster73] #478621
09/24/09 11:08 PM
09/24/09 11:08 PM
Tampa , Fl
MoparJoe Offline
super gas
MoparJoe  Offline
super gas
Tampa , Fl
I couldn't find one earlier this year when I was trying to do the same thing, I ended up making another prop shaft with 7290 on the front and a 1350 rear.
If anything you can get the weld yoke changed, it was in the $60 range for the yoke, welding, balance and 2 new spicer universals when I got it done earlier this year.
Re: 7260 -1350 conversion u-joint [Re: In_The_Pink] #478622
09/27/09 11:49 AM
09/27/09 11:49 AM
Back in Blue Jersey.
P
polara71 Offline
polara71  Offline
P
Me too , $40.00 got me what I needed ..........
