Re: 727 accumulater ??
[Re: DusterW2]
#478253
09/24/09 01:36 PM
09/24/09 01:36 PM
Posts: 316 Coolville, Ohio
Lew
Coolville, Ohio
thanks john. by the way on 2nd gear band, the little steel pin in the middle of the accum. cup that the rocker rides agianst seems to be stuck in, could that be causing my 2nd gear to be slipping?
[Re: Lew]
#478254
09/24/09 03:01 PM
09/24/09 03:01 PM
Posts: 760 Southington Ct.
turbobitt
Southington Ct.
Oh no, you didn't remove the spring from the front servo, did you ? The accumulator is the center piston that the valve body covers. The lever, or "rocker" as you call it applies second gear as the pin is forced against it when oil pressure buids behind the servo when commanded by the valve body. This should always have a spring between the cover and apply piston and in some cases it will have two.
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
[Re: turbobitt]
#478255
09/24/09 03:19 PM
09/24/09 03:19 PM
Lew
Coolville, Ohio
no sir i did not remove the spring in that trans but i just did in another old trans just to see whats in there, trying to figure these old T/F transes out, buy book, moparts, and just tearin in and seein whats in there, at the same time maybe ill figure out whats wrong with the one in our cuda, yep i could take it to the local trans shop, but i wouldnt learn anything from that.
