school me on rebuilding an 8.75 #477741
09/23/09 05:36 PM
09/23/09 05:36 PM
hi
sharpie Offline OP
Moparts Linguist
sharpie  Offline OP
Moparts Linguist
hi
So I picked up my BBP 8.75 a couple days ago. It's from a 66-70 B-body, so it should fit under the Demon without much hassle. It's a 742 case open 2.94 center section
I took it all apart, and this is what I found:
Before taking it apart, I turned over the gearset from the pinion. No backlash either direction from the pinion itself, and the axles turned nicely.
I took the axles out first and checked the splines. No issues with the splines that I can tell. No chipping, warping, or twisting.
I took the chunk out to look at it (and count the gearset) and it looks good inside. All the teeth look fine.
So i need a little schooling on what I need to/should replace, what I need to/should buy, and how to clean it well!
Re: school me on rebuilding an 8.75 [Re: sharpie] #477742
09/23/09 06:17 PM
09/23/09 06:17 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
No need to replace anything except possibly the axle seals if it was wet at the flange. Clean it with spray brake clean and reinstall. Be sure to add the suregrip aditive with the rearend lube.
Re: school me on rebuilding an 8.75 [Re: sharpie] #477743
09/23/09 06:21 PM
09/23/09 06:21 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
it will slide right in.... you will be limited with stock wheels.....
Re: school me on rebuilding an 8.75 [Re: 340dart4spd ] #477744
09/23/09 06:30 PM
09/23/09 06:30 PM
hi
sharpie Offline OP
Moparts Linguist
sharpie  Offline OP
Moparts Linguist
hi
It's a peg-leg. Hence the "open gearing".
What I'm worried about is buying the right parts. I'm missing the brake backing plates (I have an 8.25" axle with the backing plates, will those work?). I'm also missing all of the drum hardware.
What do you mean by "limited with the stock wheels?"
Re: school me on rebuilding an 8.75 [Re: sharpie] #477745
09/23/09 07:41 PM
09/23/09 07:41 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
OOPs! missed the peg leg part. I figured if you were going through all that swapping you'd go with a sure grip.
Re: school me on rebuilding an 8.75 [Re: sharpie] #477746
09/23/09 07:46 PM
09/23/09 07:46 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
send me a email sfisher@fairpoint.net
i can explain
Re: school me on rebuilding an 8.75 [Re: sharpie] #477747
09/23/09 07:48 PM
09/23/09 07:48 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Brian.....Talk to DrDiff (Cass) he is the go-to guy for anything diff related you might need or need to know.
Re: school me on rebuilding an 8.75 [Re: 340dart4spd ] #477748
09/23/09 07:55 PM
09/23/09 07:55 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
I have a b-body rear end under my 72 Duster. The perches needed to be moved in to make it bolt up. But I have factory magnum cop car style 15" X 7" wheels and it looks good on the wheel placement. If anything you will need a wheel with a 5.5" back spaced wheel to bring it back to factory position.
Re: school me on rebuilding an 8.75 [Re: 340dart4spd ] #477749
09/23/09 10:07 PM
09/23/09 10:07 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
i can explain
If it's not gonna land you in jail....post it here. It will help me too.
