Page 22 of 127 1 2 20 21 22 23 24 126 127
Re: 440 trucks [Re: smokn440] #4768
10/24/04 05:01 PM
10/24/04 05:01 PM
Hawaii
smokn440 Offline
super street
smokn440  Offline
super street
Hawaii
did i mention it was the original p.o.s. cam sprocket on there still,,,,didnt realize it until i actually pulled it off and cleaned it
Re: 440 trucks [Re: smokn440] #4769
10/24/04 05:28 PM
10/24/04 05:28 PM
CA, Proprietor; The "PALOMINO"...
dynotune440 Offline
dynotune440  Offline
it should have a fiberglass coating on the gear them on the camshaft.
Dinuba, California, Home of the PALOMINO ranch and 440 truck farm, where dodge trucks have a home. Have Four 1979 dodge PALOMINO trucks now.
Re: 440 trucks [Re: dynotune440] #4770
10/24/04 11:01 PM
10/24/04 11:01 PM
Hawaii
smokn440 Offline
super street
smokn440  Offline
super street
Hawaii
well,,,,,what a long weekend,,,,,,,put it back together by the book,,,,,,seem to have everything right,,,,,,,,,but she no wanna start,,,,blow by is real bad,,,just clickin the key it blows out a puff of smoke,,,,,i think its time to pull the ol' 440,,,,not that i have the time
Re: 440 trucks [Re: smokn440] #4771
10/25/04 12:00 AM
10/25/04 12:00 AM
Rosedale B.C Canada.. Eh
Fargo Freek Offline
super gas
Fargo Freek  Offline
super gas
I only have one more Idea... did you pop the valve covers off and see if all the push rods are moving and if they are opening the valves.. just a Idea you might want to check it out ......
I was the Black Warlock but now Iam the Fargo Freek 1950 plymouth fast back (custom) 1951 Fargo spring special 1996 Dodge 1500 Pu 2008 Magnum AWD The way I see it is If It doesn,t say MOPAR then what else is there. E Mail me @ nascar2000@telus.net
Re: 440 trucks [Re: Fargo Freek] #4772
10/25/04 12:12 AM
10/25/04 12:12 AM
Hawaii
smokn440 Offline
super street
smokn440  Offline
super street
Hawaii
had the drivers side off,,,,gonna do this one more time this week,,,,,,get back to the timing chain,,,if it all checks out right,,,then I'll probably just keep going and strip motor,,,,if I missed something,,,,I'll throw it back together one more time
Re: 440 trucks [Re: smokn440] #4773
10/30/04 01:16 PM
10/30/04 01:16 PM
Hawaii
smokn440 Offline
super street
smokn440  Offline
super street
Hawaii
sounds like it,,,,,,,but I've owned the truck around 4 years now and I never had distributor out,,,,,and this truck was running solid the whole time,,,,even 2 weeks ago trying to start it,,,,it turned over once and ran,,,shut it down and it never restarted,,,,,could it have been running 180 out????hmmmmmmmmmm,,,I think we did try to time it with a light and couldnt get it dialed in,,,,so,,,,now I've got the camshaft gear mark at the bottom,,,then i pulled it and turned the crank one turn to #1 tdc,,,then i pulled the dist. up and turned it 180 to #1,,,,now everything is lining up,,,,now if my bro-in-law ever shows up with a gear puller,,,I can put it back together
did I actually do anything here,,,,or did i just spin the distributor 180 been buggin me all week,,,back down to timing chain,,,,gonna pull valve covers today and see if everything is movin up top,,,,,man this sucks,,,,,this wasnt in the plan
Re: 440 trucks [Re: smokn440] #4774
10/31/04 04:11 PM
10/31/04 04:11 PM
Hello, I'm new to this board and this site. I hope I'm posting correctly.
I have a '78 adv se SWB 4x4 with a 440. I've read that there were not many of these made so i guess my question is...is it worth it to restore it or should I build it? Right now all the modifications are to the suspension..and i'm not sure it has the correct seat but other than that it's pretty much stock..any help or suggestions would be great!
Re: 440 trucks #4775
11/01/04 02:47 AM
11/01/04 02:47 AM
dynotune440 Offline
dynotune440  Offline
well, it would be safe to say that not many adv se 4x4 440 trucks were made, there are a bunch more of those floating arround than the 2wd's for sure. so, do you have pics of it, what options does it have, what color combo is it????? Let us know. You might even PM machoman, he has a truck registry going where he is collecting info on 1972-1980 dodge trucks.
Re: 440 trucks [Re: dynotune440] #4776
11/01/04 11:44 AM
11/01/04 11:44 AM
Thanks for the reply! I don't have a pic right now...I think the truck is fairly loaded it has a/c, cruise, ps, pb, tilt, cargo light, dual tanks, full carpet, woodgrain dash(I'm not sure if that was an option) and an automatic(not sure if that was an option either). The original color is two-tone blue/silver although right now it's mostly primer, the poor thing needs some work. also it has remote spotlights but I don't think those are stock...I am having a bit of a hard time finding info on what did or didn't come on these trucks.
Re: 440 trucks #4777
11/02/04 01:04 AM
11/02/04 01:04 AM
dynotune440 Offline
dynotune440  Offline
that sounds like it was a cool truck. the spot lights are definately not stock. where are you located at? Would like to see some pics when you get a chance.
Re: 440 trucks [Re: dynotune440] #4778
11/02/04 06:00 PM
11/02/04 06:00 PM
I'm in nebraska now but originally from Denver, thats where I bought this truck...also another question..did these trucks come with steel wheels and hubcaps? I took a few pics today...so here she is oh and btw thats a '72 holding up the camper.
Re: 440 trucks #4779
11/02/04 06:08 PM
11/02/04 06:08 PM
Here's another pic...sorry I can't figure out how to put it directly on my post...my brain is in "off" mode today.
Re: 440 trucks #4780
11/02/04 06:10 PM
11/02/04 06:10 PM
southeast, mich
MachoMan Offline
MachoMan  Offline
southeast, mich
yes they did. if the 15-10LT tire was ordered you received a 15x8in steel wheel. this wheel was available from 74-76. in 77 the chrome 5 slot became available, and i'm not sure when the wagon wheel first came out. i'm sure it was 77 also only cuz i have never seen a factory 76 w/these.
the chrome 5 slot was optional on 2wd's in 76
here is a pic of the complete set of 5 i picked up.
Please register your Dodge truck here 1972-1980 Dodge truck registry
Re: 440 trucks [Re: MachoMan] #4781
11/02/04 06:16 PM
11/02/04 06:16 PM
Cool! The junkyard down the road has a set of 4 with all the hubcaps...he wants either 50 or 100 dollars for them (he couldn't decide)...I may go pick them up just in case I go back to all stock
Re: 440 trucks #4782
11/04/04 08:35 PM
11/04/04 08:35 PM
Thunder Bay,ON
LilRedDave Offline
LilRedDave  Offline
Thunder Bay,ON
Is this an orginal 440 by it's VIN 440 PW and another 78 440
Re: 440 trucks [Re: LilRedDave] #4783
11/05/04 11:47 AM
11/05/04 11:47 AM
dynotune440 Offline
dynotune440  Offline
The first one, the MACHO PW is a factory 440 truck. The second one could be, and probably is, the auction appears to have the "B" and "D" switched arround.
Re: 440 trucks [Re: dynotune440] #4784
11/07/04 01:13 PM
11/07/04 01:13 PM
ME
79machocharger Offline
ME
Hey dynotune440 I like the original 440 Trailduster your bidding on. Original orange with the soft top and hard top. Look like a good deal with no reserve. I wish i lived closer, because i would bid on it. I love that truck it's a real nice unit, It will go good with your collection. Any way Good luck on the bidding.
http://img.villagephotos.com/p/2004-11/873524/dd_1_b.jpg
Re: 440 trucks [Re: 79machocharger] #4785
11/16/04 08:57 PM
11/16/04 08:57 PM
Fargo Freek Offline
super gas
Fargo Freek  Offline
super gas
Well I have been doing so scratchin around about this 440,s in Lil Red,s and Wwarlocks and I tell ya it,s all a bunch of Bunk someone out there is yanking someones leg big time ... Yes they had 400 but not 440...... thats my piece and Iam sticking to it Damit
Re: 440 trucks [Re: Fargo Freek] #4786
11/16/04 10:11 PM
11/16/04 10:11 PM
dynotune440 Offline
dynotune440  Offline
Got to let you in on something, I have a 77 440 warlock in metalic black, and I know of 3 other warlocks that have the big "D" in 5th position of the VIN which makes them factory 440 trucks!
Re: 440 trucks [Re: dynotune440] #4787
11/17/04 12:11 AM
11/17/04 12:11 AM
Fargo Freek Offline
super gas
Fargo Freek  Offline
super gas
Well I'll be hog swagged!!!!!
I have looked every were on getting info on that and I tell ya All the contact that I made said " HUH well I know they came with 400" and are you sure they didn,t use the "D" for the 400???? hold on.... Dam my leg feels like it,s being tugged on .ROTFLMAO
