E body fuse block #476889
09/22/09 07:46 PM
09/22/09 07:46 PM
Tacoma, Wa.
danbs23 Offline OP
danbs23  Offline OP
Tacoma, Wa.
Please help! There are two spring clips that hold the fuse blocks together at the firewall. There are holes through the clips that may need a screw. Are these clips a grounding feature or just used to hold the two blocks together? My car was apart so I don't know how it goes back together. I know bad grounds can be a real pain. Thanks.
Re: E body fuse block [Re: danbs23] #476890
09/22/09 10:11 PM
09/22/09 10:11 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
They just hold the fuse block and connector to the body, no grounding. And yes, there are two screws that go through them.
Craig
Re: E body fuse block [Re: danbs23] #476891
09/22/09 10:20 PM
09/22/09 10:20 PM
Tacoma, Wa.
danbs23 Offline OP
danbs23  Offline OP
Tacoma, Wa.
THANKS
Re: E body fuse block [Re: danbs23] #476892
09/22/09 11:44 PM
09/22/09 11:44 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Re: E body fuse block [Re: Alaskan_TA] #476893
09/23/09 05:16 PM
09/23/09 05:16 PM
London, England
Gavin Offline
Gavin  Offline
London, England
x2, Barry is correct, no screw through clip
Re: E body fuse block [Re: Gavin] #476894
09/23/09 05:29 PM
09/23/09 05:29 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
And I was wrong. Barry's picture is worth a thousand words. I was visualizing something else in my foggy mind, sorry
