didnt have to be a police engine to get 360 heads
most all 4-v 318 had 360 heads,but not all the coolers police engines had
trucks with q-jets on 318 got 360 heads also
I pay 200 for a jy tranny and jy engines..so IMO..its not to far out of range
depends on whats in your wallet I geuss
last 727 I looked at at a local jy,they wanted 350 for it...I pointed out that the kick down band adjuster was only on by 2-3 threds and I would pass on it
I got my MH 440/727 for 300,thats the only reason I went BB..
if your worryed about the 360 heds droping comp,thats usaly when it gets the 360 heads swaped on to a stock 2-v 318
the comp hieght is a tad higher on stock 4-v 318 (so I was told)to keep the comp about the same 8 to one as a stock open chamber 318 headed 318
I know a few of the roller cam pre mag engines I have torn down have the piston right around 0 deck..but they are rated 9 to 1 comp with the closed chamber #302 heads
I know I have been ordering the 9 to 1 comp replacement pistons for older 318 to get the comp up some and is working for me and my junk
