Re: Top end oiling solution ???
[Re: Stanton]
#475586
09/21/09 07:55 PM
09/21/09 07:55 PM
Posts: 8,882 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I'm generalizing here and I didn't say that "you said" to groove the journal, only that it mentions a grooved journal.
The simple fact is that too much info can be dangerous and you've scared the b'jeezus out of me with some of the stuff in that book. The last thing I want is a catastrophic failure - regardless of the power level I'm building !
Anyhow, I'm planning a 528" RB stroker with a solid roller, 10.5:1 cr, and EZ1 heads. Primarily for street use.
Right now I have the block, EZ1's, 440-2 intake, Harland Sharp 1.5 rockers and shafts, roller lifters (not pushrod oilers), complete dual line oil system and some other incidentals.
The goal is something that with a ton of bottom end so I can run 3.54's with a stick and still launch like a super stocker. I figure the Comp XR280 should do that nicely.
