best perf cam for 340 #473301
09/20/09 11:58 AM
09/20/09 11:58 AM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
for a stock -70 340 car exept torker 2 intake and holley carb. stock conv 3.23 gears.
this will be a driver.
Re: best perf cam for 340 [Re: sshemi] #473302
09/20/09 12:16 PM
09/20/09 12:16 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
You said stock converter so it must be an automatic. You won't go wrong with a Comp 268 XE. The MP 272 cam would also be a good choice. Or call Jim Dowell at Racer Brown for a custom shaft. Hughes Engines has a nice line of cams, but they tend to be high lift relative to duration so checking clearances becomes even more important than usual.
Re: best perf cam for 340 [Re: sshemi] #473303
09/20/09 12:48 PM
09/20/09 12:48 PM
Beavercreek, Ohio
OA5599 Offline
OA5599  Offline
Beavercreek, Ohio
I love my Hughes Whiplash cam. Sounds really mean, holds plenty of vaccum, and tons of low end/mid range. Good enough to put my 8.5:1 340 with no converter into the 13.20s...thats with a traction problem too. I have a few vids of it on youtube.
http://www.youtube.com/watch?v=xrqvMTafr_c
http://www.youtube.com/watch?v=iCnTKXvN0fI
Re: best perf cam for 340 [Re: OA5599] #473304
09/20/09 01:35 PM
09/20/09 01:35 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Run some type of dual plane performance intake, RPM, LD340, Air Gap, instead of the torker II.
I'd run a cast iron 340 intake with a 1-2" 4 hole spacer before putting Torker on it.
The X268H or something similar is a good choice for a street car.
Re: best perf cam for 340 [Re: RobX4406] #473305
09/20/09 01:38 PM
09/20/09 01:38 PM
Beavercreek, Ohio
OA5599 Offline
OA5599  Offline
Beavercreek, Ohio
I run a Perf RPM and don't think I would want another intake for it. Really woke up my car. Works perfect with my cam.
Re: best perf cam for 340 [Re: OA5599] #473306
09/20/09 01:56 PM
09/20/09 01:56 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
The torker II will work fine use a 4 hole spacer under the carb. i run 12.20 with a 360, flat tops, j heads, 3.91 gear.
Hughes or a vodoo, cam in the 226 to 234 @.050 would work best
