Charlies 360 oil pan seals #472957
09/19/09 10:05 PM
09/19/09 10:05 PM
Cairns Queensland Australia. T...
V
vc360 Offline OP
vc360  Offline OP
V
With a Charlies 360 oil pan what front seal are you using? Seems awfully wide across the front to accept a stock 360 seal?.. Looks to only have room for sealant? No mention from Mancini when ordering.
Thanks Darren
Re: Charlies 360 oil pan seals [Re: vc360] #472958
09/19/09 10:21 PM
09/19/09 10:21 PM
south central pa
bdaz smblk Offline
bdaz smblk  Offline
south central pa
I never found a seal to work.I always used stuff that is made by permatex called the right stuff works great.When you take the pan back off you will have to use a razor blade to cut the stuff.hope this helps Kenny.
3120lb, small block, 10.5" tire, NA, through exhaust, full int, WITH 83/4 REAR, 9.0 at 150mph
Re: Charlies 360 oil pan seals [Re: bdaz smblk] #472959
09/19/09 10:29 PM
09/19/09 10:29 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
If you go to a PHORD dealer, go to parts, and ask for the 7.3, and 6.0 power stroke oil pan sealer, its grey, and is designed to last the "service" life of the 7.3, it is AWSOME, and sets up so well that it needs to be slit with a razer knife to get it back appart. If you try to "pop" the pan loose it WILL dent. Ask me how I know...
I have found it to be the same cost of the right stuff from permatex, but cheaper...
I have a charlies pan on my 360, I just used mopar engine rtv, and its starting to leak. When the stroker gets done Im using my ford motorsport RTV.
Kasey
Re: Charlies 360 oil pan seals [Re: Moparnut426] #472960
09/19/09 10:42 PM
09/19/09 10:42 PM
V
vc360 Offline OP
vc360  Offline OP
V
Well I thought I was on the right track just using sealant. I got some of my own "Right stuff" haha.
thanks
