Broken temp sender #472781
09/19/09 04:30 PM
09/19/09 04:30 PM
dark side of the moon
Dougsmopars Offline OP
1968 440. Bad day at the office. Temp sender was looking a bit shitty so i bought a new one. Went to remove the old one head snapped of clean at water pump housing. Any good ideas on how to remove the peice broken off in the water pump housing?
Re: Broken temp sender [Re: Dougsmopars] #472782
09/19/09 04:44 PM
09/19/09 04:44 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Drill it and easy out.
Re: Broken temp sender [Re: stumpy] #472783
09/19/09 04:55 PM
09/19/09 04:55 PM
Gonna try an easy out tomorrow. Don't need to drill it as sender is hollow inside. all that was in there was a spring.
Re: Broken temp sender [Re: Dougsmopars] #472784
09/19/09 08:06 PM
09/19/09 08:06 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Wow, you said shiddy....
Re: Broken temp sender [Re: buildanother] #472785
09/19/09 08:49 PM
09/19/09 08:49 PM
SW Fla.
CYACOP Offline
CYACOP  Offline
SW Fla.
Hammer and some small chisels and cave the threads toward the center.
Re: Broken temp sender [Re: CYACOP] #472786
09/19/09 08:56 PM
09/19/09 08:56 PM
I'll give that a try.
Re: Broken temp sender [Re: Dougsmopars] #472787
09/19/09 09:01 PM
09/19/09 09:01 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
put some heat on it first. that will help a lot in getting it to breake loose and come out...
I am truckless..
