Re: Headin to the strip, 1st time down, what will it ru
[Re: Moparnut426]
#471950
09/19/09 10:46 AM
09/19/09 10:46 AM
Posts: 3,443 Northern N.J.
hemi_doug
Northern N.J.
Caltracs..... There's your answer to your traction problem...and good tires.
71 440-6 4spd & 69 Hemi 4spd
[Re: hemi_doug]
#471951
09/19/09 11:00 AM
09/19/09 11:00 AM
Posts: 12,008 Finally a HUSKER again
Moparnut426
This is a street car 90% of the time. Im just a gluton for HP, and sweet exhaust note.
Kasey
[Re: dustergirl340]
#471953
09/19/09 11:14 AM
09/19/09 11:14 AM
Moparnut426
HUH,,,
Im happy with the shocks so far, I have been beatin the crap out of the car all summer long, and they are ok, Im sure If I go to the track more often they might be bad, Dont know, but Ill cross that one when I need to.
thanks though..
Kasey
[Re: hemi_doug]
#471954
09/19/09 11:17 AM
09/19/09 11:17 AM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
I dont know about cal tracks, in his application.My s/s spring very small tire car goes high nines and sticks anywhere with unmodified leafs. I see way more posts on here from people trying to get caltracks to work than i do s/s springs by a long shot.
He has a TON of stuff to sort out before he should ever thrown in the towel on a hopefully 12 second primarily street car
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: B3422W5]
#471955
09/19/09 11:34 AM
09/19/09 11:34 AM
Moparnut426
This was a test ant tune, Im happy with the results for now, I only had limited time to run, and this was the maiden trip...
When I get more pony under the hood, then Ill really get to the down and dirty, and probbly get a dedicated wheel and tire combo for taking to the strip.
I know the tire spinn really killed me, but it was TEST AND TUNE..
KAsey
[Re: Moparnut426]
#471956
09/19/09 12:35 PM
09/19/09 12:35 PM
Posts: 4,313 Prospect, PA
BSB67
Prospect, PA
Pluss I technicaly have the 360 in the car sold so I didnt want to hurt anything.
Do I understand this correctly? You took it to the track, after you sold the engine? - That's funny.
