67 A body K frame #470856
09/17/09 11:51 AM
09/17/09 11:51 AM
Armada MICH.
DUSTER_340 Offline OP
Armada MICH.
Are these really that undiserable?
what are the differences between the 68-72 K frame.
Re: 67 A body K frame [Re: DUSTER_340] #470857
09/17/09 11:54 AM
09/17/09 11:54 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Yes, they are that undesirable. The only difference between a 67 and 68 (assuming same engine mounts) is the idler arm mount. The idler arm for a 67 is more expensive and harder to find (if you can even find one). It is also generally accepted as weaker.
Re: 67 A body K frame [Re: Jim_Lusk] #470858
09/17/09 02:09 PM
09/17/09 02:09 PM
Armada MICH.
Armada MICH.
Is there any difference in the strut rod bushing area.
Could a 67 k frame be reworked to accept the 68 and newer idler arm?
Re: 67 A body K frame [Re: Jim_Lusk] #470859
09/17/09 03:27 PM
09/17/09 03:27 PM
the house on the left.
cogen80 Offline
cogen80  Offline
Re: 67 A body K frame [Re: DUSTER_340] #470860
09/17/09 04:28 PM
09/17/09 04:28 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Sure it could have the 68-later idler arm welded on in place of the 67 stub, but at that point you might as well use the later K.
There were changes at various points over the years (67-76) to the strut rod bushing area, but these were not functional changes.
Re: 67 A body K frame [Re: Jim_Lusk] #470861
09/17/09 04:29 PM
09/17/09 04:29 PM
Armada MICH.
Armada MICH.
Thanks, does anyone have pictures of these changes?
