keeping the stock hood,any ideas????? #470782
09/17/09 11:03 AM
09/17/09 11:03 AM
indiana
mrart01 Offline OP
mrart01  Offline OP
indiana
i have a 69 dart w/the 340 bulge hood that i`m palning on running a blow thru turbo w/ the m1 single plain intake is it possible to keep my stock hood? didnt want to go w fuel injection but i REALLY want to keep my stock apperance
Re: keeping the stock hood,any ideas????? [Re: mrart01] #470783
09/17/09 11:19 AM
09/17/09 11:19 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
boy that's going to be hard. I guess you could always go with a Paxyon "carb box" instead of a bonnet. That might help w/ the height. A good carb bonnet is going to be about 3" taller than the carb. Do you have 3"'s to spare w/ that intake? You might also have to cut some of your hood supports. You should probably use a junky stock hood to check 1st.
Coming soon!!!!
Re: keeping the stock hood,any ideas????? [Re: mrart01] #470784
09/17/09 07:51 PM
09/17/09 07:51 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
try spacers between the k member and the body
Re: keeping the stock hood,any ideas????? [Re: forphorty] #470785
09/17/09 07:53 PM
09/17/09 07:53 PM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
they make low profile carb bonnets (don't believe they flow to well though) or you could try and machine some material off the top of the intake
Re: keeping the stock hood,any ideas????? [Re: prochargedhemi] #470786
09/17/09 08:01 PM
09/17/09 08:01 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
i had a procharged friend that had a bonnet so short that it screwed with the bowl venting.
