Isky lifters? #470309
09/16/09 08:42 PM
09/16/09 08:42 PM
Laredo, Texas USA
hugo Offline OP
hugo  Offline OP
Laredo, Texas USA
I just got my heads back from T&D 1.6 one shaft per cylinder. I had my indy rocker. My engines is a 400 block stroked to 500ci indy -1. Oil was block on the left side. Now I have the Isky 3772-LO-180 lifters that are suppost to oil the top. Do I have to take of the plug that restricted oil to the heads? Does anyone use these isky lifter and T&D lifter in a 400 stock block unbushed if so how does it work?
Re: Isky lifters? [Re: hugo] #470310
09/17/09 08:44 AM
09/17/09 08:44 AM
SD USA
neonic Offline
neonic  Offline
SD USA
where did you block the oil off at to the left side at the head or lifter galley. If you blocked off to the head you will oil through the push rods.
Re: Isky lifters? [Re: neonic] #470311
09/17/09 09:15 AM
09/17/09 09:15 AM
Laredo, Texas USA
hugo Offline OP
hugo  Offline OP
Laredo, Texas USA
It was in the side of the block and a line feeds the indy heads. I guess is the galley.
