Re: Dyno day for my 505 - Results are in AGAIN
[Re: TonyS451]
#469974
09/19/09 10:26 AM
09/19/09 10:26 AM
Tony, how about scanning the dyno information and posting it so we can see some actual Data. the proof of how the engine runs is in the details of the recorded data, not just the HP and torque numbers. what kind of dyno was it on?
Re: Dyno day for my 505 - Results and NEED HELP!
[Re: TonyS451]
#469975
09/19/09 10:28 AM
09/19/09 10:28 AM
Posts: 5,484 SoCal
Brian Hafliger
SoCal
What does the chamber measure? They are usually 85-86 OOTB, and with cnc work, they will be larger. So did you have them milled any? By your specs, assuming an 86cc chamber you have 10:1. Coupled with the large cam duration, you have no cylinder pressure. That will no doubt take some power away from that engine. If you read my first post, and check out the build I did in the link, you'll see we used a cam with only 236@ .050 to achieve 535HP and 620TQ!
Brian Hafliger
[Re: Brian Hafliger]
#469976
09/19/09 10:48 AM
09/19/09 10:48 AM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
I did see your link and combos like your are exactly why I feel my numbers are down. The heads were resursaced by Modern to bring the chambers down to 82cc. My engine builder cc'd a couple just to confirm, and they were 81 and 82cc.
Dram - I don't have a scanner but I'll try to type in the hp and tq numbers by rpm. The only other relevant numbers I have on my printouts are man vac by rpm. Would it help to see those too? I think he said it was a DTS dyno.
2 kids and a dog
#469978
09/19/09 11:04 AM
09/19/09 11:04 AM
Posts: 9,874 Weddington, N.C.
Streetwize
Weddington, N.C.
Tony, Thanks for posting the results. I've never seen much diference between the M1 and the SD, I just prefer the SD because it'll fit under the hood of a b/e even with a small spacer and the SD has runners that are easier to work (The M1's are kinda tall and narrow for the same sqare area.) A lot of the flow improvement to the SD is in the 'as cast' roof so It needs a little spacer to "fix" the turn radius. The rest of the changes are really just opening up the runners for more flow area which a stroker likes. Your results are skewed by a the too big headers, a torque curve is also a MOMENTUM curve which has a big effect on how a motor pulls through a load. Your motor for its compression and port area was at a big disadvantage below 4000 because your motor had no "sweet spot" to gain RPM bacuase the exhaust had no velocity (lazy). that effects overlap scavenging and when you have smallish runners to begin with....well, it all ties together. When you put the 2" on it it'll feel a lot stronger from about 3600 up and it will broaden the torque curve AND make more power. If you keep the SD I can shoot you some porting ideas but I think I'ds go with the indy dual plane with some pretty easy to do lower plenum work, that will be a better all around intake for the street and won't cost you any appreciable power up top. If it did, I wouldn't run one in max wedge form.
[Re: TonyS451]
#469979
09/19/09 11:09 AM
09/19/09 11:09 AM
Posts: 8,716 Baltimore/Denver
64Post
Baltimore/Denver
Tony,
Maybe you can take a good picture of the dyno sheet then upload the picture here. That's what I used to do in the old days.
[Re: TonyS451]
#469980
09/19/09 11:21 AM
09/19/09 11:21 AM
TonyS451
Chicago, IL
Here are the vac / TQ / HP numbers from the last pull the M1 intake and cam advance:
3800 - .6 544 396 3900 - .6 545 405 4000 - .6 548 417 4100 - .6 553 433 4200 - .7 554 443 4300 - .8 551 452 4400 - .8 549 460 4500 - .9 550 471 4600 - 1 555 487 4700 - 1 561 503 4800 - 1.1 564 515 4900 - 1.2 565 527 5000 - 1.2 564 537 5100 - 1.3 560 544 5200 - 1.3 553 549 5300 - 1.3 545 551 5400 - 1.3 538 553 5500 - 1.3 534 559 5600 - 1.4 528 563 5700 - 1.5 518 562 5800 - 1.5 509 563 5900 - 1.5 499 560 6000 - 1.5 486 555 6100 - 1.6 474 550 6200 - 1.6 462 545 6300 - 1.6 452 541 6400 - 1.7 444 540 6500 - 1.7 434 537
2 kids and a dog
[Re: TonyS451]
#469981
09/19/09 11:24 AM
09/19/09 11:24 AM
don't bother typing in those numbers without the rest of the data. go back to your dyno guy and ask for a full printout of ALL data as recorded for your best pull. the HP and torque numbers are meaningless without them.
#469982
09/19/09 11:29 AM
09/19/09 11:29 AM
TonyS451
Chicago, IL
Dram - What other numbers/info are you looking for? Just so I know when I ask him. Also, what is your opinion of how much running the 2 1/4 headers hurt this combo?
2 kids and a dog
[Re: TonyS451]
#469985
09/19/09 01:59 PM
09/19/09 01:59 PM
Posts: 4,313 Prospect, PA
BSB67
Prospect, PA
Tony I would be a little concerned if the Dyno operator is not actively engaging you in conversation regarding A/F ratios, fuel consumption and BSFC, among other things after each pull, if he is not reviewing and printing out complete data files between each run or at the end of the session for you to take home, and if printing, scanning and emailing records is technically challanging.
None of this makes the HP and TQ data any more or less accurate, or any higher or lower, but overall seems odd to me.
[Re: BSB67]
#469986
09/19/09 04:35 PM
09/19/09 04:35 PM
TonyS451
Chicago, IL
It wasn't trying to imply he finds the computer technically challenging. He's actually very bright, just never leaves the shop long enough to get with the times. Literally, he never leaves the shop and he is always working, and I just don't think he has gotten around to picking up the computer. I know its not normal, even my 5 year old can navigate a bit on the computer and internet.
However, I agree it would have been nice to have more data than what I got. I'm going to see if I can get a printout of all the data. If I get it, I will try to scan or at least post some of the pertinent info.
2 kids and a dog
[Re: Defbob]
#469988
09/20/09 08:31 AM
09/20/09 08:31 AM
TonyS451
Chicago, IL
That is a cool/quick car Defbob, and a rag top to boot! Nice DusterDave - thanks for the link, that was very informative.
2 kids and a dog
