hybrid 727 #469088
09/15/09 02:17 PM
09/15/09 02:17 PM
nc
E
emarine01 Offline OP
E
nc
Is it possible to build a 904 in a 727 case? or use the best parts from a 904 in a 727, this is for a 4x4 application and I don't want to shift any weight forward switching from a 727 to a 904 and I cant move the engine any further back, are there any options here
Re: hybrid 727 [Re: emarine01] #469089
09/15/09 04:08 PM
09/15/09 04:08 PM
Wisconsin
Garceau Offline
Garceau  Offline
Wisconsin
Yes there is....but not sure how. I thought I remember people putting 904 stuff into the 727 because the 904 is faster do to less rotating mass.
Re: hybrid 727 [Re: emarine01] #469090
09/15/09 04:11 PM
09/15/09 04:11 PM
Hemiroid Offline
Hemiroid  Offline
It's been done forever. Stockers and SSers use them today. Talk to Smith at Pro-Trans. Not sure one would live in a 4x4 though
Re: hybrid 727 [Re: Hemiroid] #469091
09/15/09 04:50 PM
09/15/09 04:50 PM
nc
E
E
nc
Cool, I wasn't sure if it was a totally retarded question If I can put most of a 904 in a 727 will it still free up some power & weight?
Re: hybrid 727 [Re: emarine01] #469092
09/15/09 09:06 PM
09/15/09 09:06 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Yes it will but it's NOT CHEAP , and you'll have to go thru it often .
Re: hybrid 727 [Re: JohnRR] #469093
09/16/09 09:14 AM
09/16/09 09:14 AM
nc
E
E
nc
Well I don't know what sounds worse the not cheep in caps or go thru it often, One thing about my porkflite it has been very reliable at the power levels we run, the fact that a 904 frees up so much power is very appealing, is there a way to free up power in a 727 that would be more cost effective & stronger? We have become good at trashing drive line parts in the last few years, the cost of a 904 does not really bother me that much if it can make a season with out failure but the thought of building several of the them in a year wont cut it
Re: hybrid 727 [Re: emarine01] #469094
09/16/09 09:45 AM
09/16/09 09:45 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Put lightweight parts in the 727 and fully rollerize it ? You'll have to keep up with band adjustments and fluid changes if you get an alum front drum, don't use a kelvar band on it, soild red lined, initial cost will be cheaper than one of those 727 with 904 internals, which I think cost 5k and/or more ...
Re: hybrid 727 [Re: emarine01] #469095
09/16/09 10:07 AM
09/16/09 10:07 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
I thought you were going to start drag racing?
Re: hybrid 727 [Re: S/ST 3040] #469096
09/16/09 10:39 AM
09/16/09 10:39 AM
nc
E
E
nc
I cant make up my mind, we are so close to a light class record on dots that If I quit before I give my best shot , well you know what I mean, the record was set 9 years ago and I am 3/100s off, only problem is that I have slowed some this summer, truck never liked the heat, I am still huntin for a A body but it seems that I am more picky than I thought,the last time I drag raced was at englishtown on a 900 kawi 30 years ago so I will be startin from scratch, some of it is the economy also, dont want to get in too deep with 3 kids and the fact that we own horses< giant waste of major bucks> but the wife & kids like them, looks like this winter we will regroup and pick a direction
Re: hybrid 727 [Re: emarine01] #469097
09/16/09 05:50 PM
09/16/09 05:50 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The stock class racers put 904 guts in the 727 case because the class rules specify the original case must be used; for non-stock racing, mating the 904 to a big block can be done with an Ultrabell housing. Lots cheaper than adapting the 904 guts.
Re: hybrid 727 [Re: John_Kunkel] #469098
09/16/09 07:46 PM
09/16/09 07:46 PM
nc
E
E
nc
It looks like any investment into a good trans for a 4x4 will carry over to a drag car with a change in output shaft, How much power does a roller 727 free up?
Re: hybrid 727 [Re: emarine01] #469099
09/16/09 09:13 PM
09/16/09 09:13 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
You'll spend around $6K on a Pro Flite (727 with modded 904 internals). They can be ordered with one of the 20 or so gear ratios available for them. Don't think it would hold up too long in a 4x4, as they are a high maintenance item in a Comp car.
Speak to someone like John Cope or Rick Allison about your options
AL....
Alan Jones
Re: hybrid 727 [Re: LA360] #469100
09/16/09 11:03 PM
09/16/09 11:03 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
I know a 68 340 barracuda that run F/SA in nhra and he uses a 904......the trans was bought from protrans, I asked about the 727, he said they could now run 904s.
that trans with the 904 liteweight parts and low drag was around 6k.
Tony
70 AARCuda Vitamin C
Re: hybrid 727 [Re: 70AARcuda] #469101
09/16/09 11:35 PM
09/16/09 11:35 PM
S/ST 3040 Offline
S/ST 3040  Offline
2009 NHRA Rule Book (pg. 107) Stock
TRANSMISSION, Automatic
Any model transmission (Must be same make as car) having same number
of forward speeds. (OD gear not required) and reverse permitted.
Transmission case must be OEM from a standard automotive application
as found in the Official NHRA Stock Car Classification Guide.
NHRA-accepted adapter plates permitted............
I looked up that Classification Guide and didn't find anything that specified applicable transmissions.
Re: hybrid 727 [Re: LA360] #469102
09/17/09 09:42 AM
09/17/09 09:42 AM
nc
E
E
nc
Well 6k is not in the trans budget this year, I was hopin to come in under 2k so time to go another way, In mud racing we don't torque up on parts like drag racing,just not enough bite on the hit, so a 904 my live longer in this application, does anyone know how much shorter a 904 case is from the bell to the back of the case where the sprag is? I may be able to move the fire wall back where the dist is a few inches and set the engine further back, this is a good option for me as we are way to front heavy now and it would save me from making up 2 new drive shafts and a transfer case mount
Re: hybrid 727 [Re: emarine01] #469103
09/17/09 09:57 AM
09/17/09 09:57 AM
S/ST 3040 Offline
S/ST 3040  Offline
I can't give you the difference, since I don't have any 727s handy
but, from the mating surface of the bell housing to where the tailshaft
housing bolts on, is 15.875" on a 904.
Transmission mount is in the same location as 727 but, OAL is 3.9" shorter.
Re: hybrid 727 [Re: S/ST 3040] #469104
09/17/09 10:11 AM
09/17/09 10:11 AM
nc
E
E
nc
Thankx Vic, my porkflite is 17" I will have to find a adapter housing from a 904 to the trans case and measure there also, I am assuming that the tail shaft housing has a different bolt pattern?
Re: hybrid 727 [Re: emarine01] #469105
09/17/09 10:16 AM
09/17/09 10:16 AM
S/ST 3040 Offline
S/ST 3040  Offline
Most likely.....I think the KD levers, speedometer assemblies, valve bodies
and filters are the only interchangable pieces between them.
Re: hybrid 727 [Re: S/ST 3040] #469106
09/17/09 10:25 AM
09/17/09 10:25 AM
nc
E
E
nc
Well at least I have a couple of spare filters to offset the cost some I picked up 3 727 cores so I can dissect them and start to figure out whats goin on, Looks like some 904s are in order, I will post on the truck form and see if I can learn some more on the output shaft side for 4x4s
Post deleted by Defbob [Re: emarine01] #469107
09/17/09 10:32 AM
09/17/09 10:32 AM
