Just picked up a 76 440 what pistons for 0 deck?
#468549
09/15/09 12:31 AM
09/15/09 12:31 AM
Posts: 2,682 Clinton Twp. Michigan
coronet1966d
i just picked up a super clean 76 440 with under 50k from a motorhome im going to do a budget build looking for right around 9.5:1-10:1 CR with the 452 heads i have OR i may end up getting 915 or 516 heads if thats the better route my pistons sit about .120 in the hole i didnt believe you guys when reading on here about the later 70's 440s untill i saw for myself basicly looking for a flat top piston that i can use for a zero deck setup and i will most likely be using hyperutectics to keep the cost down one more question i have is what kind of power will the stock rods and cast crank handle? is it unrealistic to run 12's with a stock crank/rods? im running a somewhat weight reduced 85 d100 SWB that currently runs 13.8@99 with a 1.99 60' with a 10:1 360 and a 474 purple shaft 833OD my overall goal with this build is to run 12's heres what a $300 440 looks like
Re: Just picked up a 76 440 what pistons for 0 deck?
[Re: coronet1966d]
#468550
09/15/09 04:05 AM
09/15/09 04:05 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
The 440 'spec' deck height is 10.725", with the stock 6.768" rod length, and stock crank stroke of 3.75" (use 1/2 stroke for calculating piston height to TDC) 10.725 - (6.768 + (0.5 * 3.75)) = piston compression height = 2.082" Just about all the pistons ate a bit shorter so the block can be decked. Keith Black #237 has a 2.067" compression height (0.015" below deck) with 5cc valve reliefs and it is a flat top piston. KB also sells a forged version #9953 with the same 2.067" CH, and 5.6 cc valve reliefs. Speed Pro sells the Forged #2355 piston with a 2.061 CH, and 7cc valve reliefs. Looking at Summit prices, the KB237 = $319.95 set, SP2355 = $367.60, Speed Pro Hypereuthic flat top 2.060", 5cc # PH147 = $319.92, SRP forged #21345x, 2.062", 6cc, $490.88.
I could not find a price for the KB forged #9953 pistons? The speed pro #2355 forged pistons are priced good, but they are a heavy piston. The other pistons will be lighter weight. I din't bother posting the other brands like JE, Ross, etc because they were all over $600 set.
[Re: 451Mopar]
#468551
09/15/09 07:43 AM
09/15/09 07:43 AM
Posts: 4,503 NJ
440challenger
NJ
[Re: 451Mopar]
#468554
09/15/09 11:01 AM
09/15/09 11:01 AM
coronet1966d
451mopar: thanks for the part numbers and prices thats going to be very helpful. i went to mancinis site and they list the KB237 as a 9.5:1 piston with 88cc heads i wonder what that CR would be with a set of 915s and im assuming that its no big deal to deck the block .015 to make that a 0 deck setup and with the correct head gaskets i could have a nice quench area with im assuming roughly 10.5:1 overall CR and that should be fine with pump gas...right? wild bill: im hoping that when this build is all said and done my goal of hitting 12's turns out to be a conservative one. realisticly i want a pump gas driver thats fun to drive on the street but i also want to put up respectable numbers at the track. if any of you guys out there reading are scratching your heads wondering about a part of this build please jump in, id like to hit my performance goals with a relativly small investment. so stroker kits are out the window, aluminum heads are most likely not going to be used (at least right away) if theres a cheap easy way please point me in the right direction. i read the post about smogger builds running 12's with stock "mile in the hole" pistons with a cam, headers and intake. if thats realistic i suppose id rather just go that route and save some money for a paint job
[Re: coronet1966d]
#468556
09/15/09 12:07 PM
09/15/09 12:07 PM
Posts: 75,089 A Banana Republic near you.
JohnRR
With iron heads and the right cam , yes it's possible ... but then again the RACE gas at the local track comes from a PUMP
[Re: 1_WILD_RT]
#468558
09/15/09 12:54 PM
09/15/09 12:54 PM
DaytonaTurbo
Manitoba, Canada
KB237's are the pistons you want. Have the block squared and milled so the pistons are all at zero deck and you're in great shape if you want to build for quench. If I was going so far as to rebuild the bottom end, I would spring for a set of edelbrock rpm or 440source stealth heads. Aluminum, closed chamber for quench and good flow, you will be able to run it on pump gas without problem.
I see you saw the smogger 440 thread, so you already know you can run 12's without touching the bottom end. If you do the bottom end and build for at least 10:1 compression you should be running 11's if you can get traction.
FWIW if money is an issue(isn't it always...?) I would be inclined to just go the bolt-on route for now. Your low mileage motorhome bottom end will happily do the job for the time being. You can still give the motor a paint job, regasket it, do cam, intake, headers and do valve springs and seals on the heads and have money left over to take a look at stuff like rear gears, limited slips, transmission issues, etc.
[Re: 1_WILD_RT]
#468561
09/15/09 02:29 PM
09/15/09 02:29 PM
Posts: 17,907 S.E. Michigan
ZIPPY
S.E. Michigan
Roll it over, get a look at the bearings.. If they are ok (probably are) just bolt some decent heads on it (Edelbrocks/MP-452's/Stealths)select a cam that builds cylinder pressure & go have fun....
That, and a typical .500 or so lift el cheapo camshaft, and you'll have found the easy way to get enough HP to get into the 12s.
The hard(er) way is to take whatever iron heads, open or closed chamber, valve job/guides/etc, spend about 3/4 of what the aluminum heads would have cost, and it'll end up with less power but probably still enough to meet your goal.
Your truck is an ideal candidate for a MP .528 solid lifter cam (or something similar with wide lobe separation), performer rpm or equivalent MP intake, and any of the aluminum heads above, though. That way you'll have an adjustable valvetrain on hand and when the inevitable urge strikes to go faster.....then you can do a shortblock with more compression/bigger cam and springs, and you'll be in the 11s.
[Re: 451Mopar]
#468566
09/15/09 04:58 PM
09/15/09 04:58 PM
coronet1966d
well i did it, i tore apart the lower end and im glad i did too. a few of the rod bearings were scored and you could see the bronze colored layer in the scratches the mains had some scoring too the last main had some pretty deep marks in it and i can feel the marks with my nail in just about every journal. i think im just going to keep an eye out for a forged crank and do the lower end right ill just move the estimated completion date back a little now i just need a bucket so i can start dumping money into it
[Re: coronet1966d]
#468568
09/15/09 05:34 PM
09/15/09 05:34 PM
Posts: 3,958 SW Fla.
CYACOP
SW Fla.
I have one of those buckets myself.
