Re: Leaf Spring relocation pics?
[Re: chargermop]
#468532
09/16/09 05:21 AM
09/16/09 05:21 AM
Posts: 2,709 NJ central
Scamp408
NJ central
last one of the back. I have also lowered the car 2" ....
How close is the pass side spring to the gas tank?
[Re: Ron Silva]
#468533
09/16/09 09:16 AM
09/16/09 09:16 AM
Posts: 3,968 North Riverside IL & Lowell IN
GTXKen
super gas
super gas
67 Valiant, minitubbed and springs relocated into the frame with a Mopar kit. I used a steel rod to keep everything square until it was all tacked in place. Then you have to CUT the rod to get it out!
Nice work Wish I could get you to help me with my 66
[Re: Ron Silva]
#468535
09/16/09 10:49 AM
09/16/09 10:49 AM
Posts: 22,696 Bitopia
jcc
Bitopia
When I relocated my front spring hangers, I was not satisfied with the inside unsupported hanger, and I added a gusset seen in the attached pic. Just a thought.
[Re: Sixpak]
#468537
09/16/09 02:47 PM
09/16/09 02:47 PM
Scamp408
NJ central
If you are running a fuel cell I don't think there's an issue as to whether you mount the box on the outer or inner wall of the stock frame rail. But if you are running a stock tank, I think you need to mount the box so its flush with the inner wall of the frame rail, otherwise you may have clearance issues between the leaf spring and the sides of the gas tank.
Looks tight to me
[Re: Ron Silva]
#468539
09/16/09 06:33 PM
09/16/09 06:33 PM
Posts: 4,152 SO. CAL.
70blackfish
SO. CAL.
that is a great way to do it!
[Re: LA360]
#468540
09/16/09 07:46 PM
09/16/09 07:46 PM
Posts: 1,613 Deerfield, Ohio
70dusterjohn
Deerfield, Ohio
I have seen instances where people will shorten the tank to clear the leaf spring. AL....
No, I spaced mine right in the middle, equal on each side, and never had any problems with the spring being to close to the tank. It never hit at all. I have went to a cell now though, not for that reason though. I figured that 9.80s on a stock tank was good but if something happen it wouldn't be good..
[Re: 70dusterjohn]
#468541
09/18/09 08:59 PM
09/18/09 08:59 PM
Posts: 6,136 Melbourne , Australia
LA360
I know in my case, the factory tank isn't an issue as I will be running a fuel cell. What plate thickness is used for the spring boxes? AL.....
Alan Jones
