Koni shock adjustment question #468336
09/14/09 09:16 PM
09/14/09 09:16 PM
south louisiana
lowell66dart Offline OP
south louisiana
I have an older set of Koni's on my Dart. These are the one's that you have to remove and twist or turn to adjust. Anyone have a link or can explain how these work. Tried a search here and Koni's site but came up empty.
2021 Dodge 2500 4WD Cummins
2020 Challenger R/T Scat Widebody
2007 Charger R/T 5.7
Re: Koni shock adjustment question [Re: lowell66dart] #468337
09/14/09 11:01 PM
09/14/09 11:01 PM
St. Louis Mo.
10 o to go Offline
"Happy Don"
10 o to go  Offline
"Happy Don"
St. Louis Mo.
mine are from 1988 still on car just readjusted them you have to screw the spanner nuts down pull the retainer at top that holds spring ,collasp shock turn in or out .You will feel it easier or harder now.Make sure you measure where the shock eyelets are or threads at bottom tospanners.
good luck don
2009 418" build dan smith built new 9.96 131.82 6.23 108 1.30 60 foot best to date 9/15/09 8in 727 430 dana 2860 lb 3040 lb w driver
Re: Koni shock adjustment question [Re: 10 o to go] #468338
09/15/09 08:25 AM
09/15/09 08:25 AM
south louisiana
south louisiana
Sorry, should have been more clear in my post. These are not coilovers, there spa1's. Looks like a stock shock. I think I remember having to collapse the shock to adjust it.
