Re: Stock block strenght??? [Re: Big B] #467801
09/15/09 03:28 PM
09/15/09 03:28 PM
Longview, Texas
marvo451 Offline
marvo451  Offline
Longview, Texas
B1Ken, are your motors aluminum rods?
Re: Stock block strenght??? [Re: marvo451] #467802
09/15/09 05:45 PM
09/15/09 05:45 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
Has anyone used cross bolt mains on the RB before and are they any stronger than stock caps.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Stock block strenght??? [Re: deaks] #467803
09/15/09 11:48 PM
09/15/09 11:48 PM
bcrproducts Offline
super gas
bcrproducts  Offline
super gas
Cross bolting the stock block actually weakens the block and can cause create stress risers in the area that you drill the side of the block. You can't compare a B or RB to a Hemi which had a different casting/core box when created with extra material to make that setup work. Been done many times on B R/B but the setup time to do this is very expensive at the shop level and has been proven to not be as effective as just aluminum caps and or a girdle setup.
Greg
www.bcrproducts.com
Re: Stock block strenght??? [Re: bcrproducts] #467804
09/29/09 10:25 PM
09/29/09 10:25 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Will aluminum caps live in street use for extended periods? Like thousands and thousands of miles?
Will they extend block life and be better than some sort of steel caps?
