Stock block strenght???
#467781
09/14/09 10:49 AM
09/14/09 10:49 AM
Posts: 2,028 Trumbull,CT.
jim sciortino
Trumbull,CT.
Can a 400 block at 500ci with a 4.150 arm be expected to live in a honest 6oo-625hp N/A, 93 octane pumpgas engine with a sharp tune???
And if so, what would it need??? Aluminum caps, girdle, etc......
Or....
When will an iron aftermarket lowdeck block hit the stores???
And...
What ported iron head (Stage 5, Max Wedge, 915) for the stealth factor, would be the way to go???
Thanks.
Re: Stock block strenght???
[Re: jim sciortino]
#467782
09/14/09 11:12 AM
09/14/09 11:12 AM
Posts: 351 michigan
64ssmax
michigan
Or....
And...
Thanks.
I have been beating on a 1964 426 wedge block with a eagle 4.150 in my 66 satellite for 2 years.
I believe you need to stay under 1974 for the good 400 blocks.
"Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end"
[Re: jim sciortino]
#467783
09/14/09 11:41 AM
09/14/09 11:41 AM
Posts: 43,296 Bend,OR USA
Cab_Burge
My street/strip pump gas low compression 518 C.I. low deck 400 block has ductile iron main caps and ARP main studs, no fill. It made 612 hp and 644 ft lbs on California pump gas in 2003 when I first dyno tested it with ported big valve 906 heads. I have since changed the heads to Eddy MCH CNC ported RPM and crankshaft(4.25 to 4.300 to up the compression from 9.25 to 1 to 10:29 to 1), it now makes 720 hp and 740 FT lbs on Oregon pump gas. 300 to 400 runs and some street miles, less than 3000 miles or so My block is a 1976 that ended up needing four sleeves and the deck brazed up due to ablown head gasket, it was the only block I could find at that time I have seen and broken the man webs in several 426W and 440 blocks bot no low decks so far
[Re: Cab_Burge]
#467785
09/14/09 12:26 PM
09/14/09 12:26 PM
jim sciortino
Trumbull,CT.
Good info..... thanks Cab.
The reason I ask is because we had a 440 block w/ stock caps, w/440-1s in the mid 90s that went low 9s @145+ @ 3280#, N/A. After about 80 or so passes and almost 4 years of street pounding, we took the engine apart only to find cracked webs. We were still driving it around like that for who knows how long.
[Re: supercomp]
#467787
09/14/09 01:24 PM
09/14/09 01:24 PM
Posts: 2,172 Ohio
theclutcher
Ohio
Stronger than i thought from watching combos since the strokers came of age...
[Re: theclutcher]
#467788
09/14/09 01:49 PM
09/14/09 01:49 PM
bcrproducts
super gas
super gas
When we designed the modern BB Mopar cap and girdle system you see today it was for more than a few reasons. Many people said why bother when a World block is X dollars and you are going to have almost that into a stock block etc. Many of us are on low budget race mode and have friends that are machinists and have a few blocks laying around or have a build that suits a cap and girdle as far as expected HP. I have been pleasantly surprised at how much HP these motors will take at some of my customers HP levels. SuperComp is a great example of what can be achieved and still be reliable. A lot has to do with preparation and starting with a good solid foundation"sonic test every block no matter what year" I have seen late model blocks that are .050 thicker than early so don't go by the year thing at all. Another reason I am an advocate of this system is we all don't have the luxury of being able to get a World or Indy block at the corner store like some of you can. I live in Canada and to get a World block I pay close to twice what most of you do by the time all is said and done. Many of my customers are in the same boat as in my European customers. I have no idea how all these BB cores ended up in Finland Australia New Zealand the Netherlands Etc but there is a tremendous amount of racing going on in Europe that most of you are not even aware of. I calculated that 40% of my business was Outside the USA and Canada last year and those guys don't have the luxury of buy it at your local speed shop. Try shipping a block to Europe or Canada and see what the freight costs you. I have had UPS shipments cost me 40% of the value of the goods that UPS charges me in Brokerage fees. This is why I get upset sometimes when people say why waste your time with stock blocks. We have proven they can work and sometimes we just don't have any other options---Greg www.bcrproducts.com
[Re: bcrproducts]
#467790
09/14/09 03:18 PM
09/14/09 03:18 PM
Posts: 976 ontario canada
mac56
ontario canada
www.bcrproducts.com
I hear ya brother on the cost to get things to the great white north.
[Re: B1Ken]
#467791
09/14/09 03:20 PM
09/14/09 03:20 PM
mac56
ontario canada
I have been running 511 B-1's for many years in Super Gas using 400 blocks with steel main caps. They make about 875 + HP and I've never had a block failure. I used to break cranks but since I switched to an ATI damper (from a Fluidamper) I haven't broken one.
It is good to have you back Ken. Your real world posts have been missed by me anyway.
[Re: Cab_Burge]
#467792
09/14/09 08:55 PM
09/14/09 08:55 PM
Posts: 1,131 Thigh-Gap Junction
New user name, Same old jerk!
Thigh-Gap Junction
... It made 612 hp and 644 ft lbs on California pump gas in 2003 ... it now makes 720 hp and 740 FT lbs on Oregon pump gas.
Oregon pump gas will beat California pump gas every time. Thanks for the proof.
[Re: jim sciortino]
#467793
09/14/09 09:04 PM
09/14/09 09:04 PM
Thigh-Gap Junction
... After about 80 or so passes and almost 4 years of street pounding, we took the engine apart only to find cracked webs. We were still driving it around like that for who knows how long.
A 1/2" or thicker girdle will almost eliminate the mode of vibration that places the main saddles in tension. Add thick cylinders and you should be good to go. Don't buy the 3/16" aluminum girdle I saw on ebay, that thing is a friggin joke.
bcrproducts : Have you had any reports of block failures with your girdle system installed?
[Re: @#$%&*!]
#467794
09/14/09 10:00 PM
09/14/09 10:00 PM
bcrproducts
super gas
super gas
I have had no feedback of block failure as of yet.If I was lying someone on this forum would speak up and make me look foolish. I have always been upfront and honest with my customers. We are going on three years with this product and several hundred sales so that is a pretty good indicator of how well this system works. Has there been failures that I do not know about --likely-- but even World and Indy motors blow up from time to time that's racing. Cheers --Greg www.bcrproducts.com
[Re: Cab_Burge]
#467796
09/15/09 10:28 AM
09/15/09 10:28 AM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
I think so long as detonation is not present and the machining and caps are good material you will have no trouble over time at that level. You could run a gircle but I personally don't think you need one for 650hp so long as it doesnt detonate but insurance sometimes helps you sleep att night. Sonic test any core block. The years and "230" myths are just that...
[Re: Cab_Burge]
#467797
09/15/09 01:15 PM
09/15/09 01:15 PM
Thigh-Gap Junction
Don't forget the CNC ported Eddy heads and the increase C.I. amd the increase in compression ratio as well as our(Oregon) now diluted 10% ethanol pump gas BTW, I did the last dyno test on non ethanol 93 octane pump gas Which is available here in Bend
In the interest of brevity I did some editing
[Re: mac56]
#467798
09/15/09 01:50 PM
09/15/09 01:50 PM
Posts: 16,932 NC
440Jim
NC
Ken gave me the info that gave me the confidence to build my 511 low deck in a factory 400 block. I decided to use aluminum main caps from BEST Machine. Let's see, this block has 437 passes on it. So far so good, and it is over 600 hp going 9.30s at 3200 lbs.
[Re: 440Jim]
#467799
09/15/09 01:59 PM
09/15/09 01:59 PM
Posts: 2,825 Sk. Canada
RemCharger
Sk. Canada
Jim, you mean like 250hp over 600....?
