Anyone have PCM wiring pin out diagram 04 RAM? #466658
09/12/09 09:18 PM
09/12/09 09:18 PM
Tampa FL
hemibeep Offline OP
hemibeep  Offline OP
Tampa FL
Does anyone have the pin out wiring diagram for 2004 5.7 liter ram with manual tranny??? Having wiring issues and would like to find out which connector supplies the coils...
thanks
Re: Anyone have PCM wiring pin out diagram 04 RAM? [Re: hemibeep] #466659
09/13/09 08:07 AM
09/13/09 08:07 AM
N.J. north west
1972challenger Offline
N.J. north west
Some one with a dealer connect log in can get you a diagram
Re: Anyone have PCM wiring pin out diagram 04 RAM? [Re: 1972challenger] #466660
09/13/09 09:28 AM
09/13/09 09:28 AM
louisiana,usa
O
olemopar Offline
olemopar  Offline
O
louisiana,usa
GO TO dto.vftis.com PUT IN YOUR INFORMATION AND IT WILL PULL UP THE CONNECTION AS PER INFO INPUT
THAD SHIERS
Re: Anyone have PCM wiring pin out diagram 04 RAM? [Re: olemopar] #466661
09/13/09 11:39 AM
09/13/09 11:39 AM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Not a srt right?
Re: Anyone have PCM wiring pin out diagram 04 RAM? [Re: SALEM1912] #466662
09/13/09 11:44 AM
09/13/09 11:44 AM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
POWERTRAIN CONTROL MODULE C2 (NGC) - ORANGE 38 WAY CAV CIRCUIT FUNCTION
1 K10 18DB/OR COIL CONTROL NO. 6
2 K16 18DB/YL COIL CONTROL NO. 5
3 K15 18DB/GY COIL CONTROL NO. 4
4 K58 18BR/VT INJECTOR CONTROL NO. 6
5 K38 18BR/OR INJECTOR CONTROL NO. 5
6 K447 18TN/YL (5.7L) ETC MOTOR (+)
7 K18 18DB/OR COIL CONTROL NO. 3
8 K35 18DB/VT (5.7L LIGHT DUTY) EGR SOLENOID CONTROL
9 K17 18DB/TN COIL CONTROL NO. 2
10 K19 18DB/DG COIL CONTROL NO. 1
11 K14 18BR/TN INJECTOR CONTROL NO. 4
12 K13 18BR/LB INJECTOR CONTROL NO. 3
13 K12 18BR/DB INJECTOR CONTROL NO. 2
14 K11 18BR/YL INJECTOR CONTROL NO. 1
15 K922 18BR/DB (5.7L) THROTTLE POSITION SENSOR GROUND
16 - -
17 K199 18BR/VT O2 2/1 HEATER CONTROL
18 K99 18BR/LG O2 1/1 HEATER CONTROL
19 K20 18BR/GY GEN FIELD CONTROL
20 K2 18VT/OR ECT SIGNAL
21 K22 18BR/OR TP NO. 1 SIGNAL
22 K34 18DB/LG (5.7L LIGHT DUTY) EGR SENSOR SIGNAL
23 K1 18VT/BR MAP SENSOR SIGNAL
24 K942 18BR/LG (EXCEPT 4.7L) KNOCK SENSOR NO. 1 RETURN
25 K42 18DB/YL (EXCEPT 4.7L) KNOCK SENSOR NO. 1 SIGNAL
26 - -
27 K900 18DB/DG SENSOR GROUND
28 K122 18BR/DG (5.7L) TP NO. 2 SIGNAL
28 K961 18BR/VT (EXCEPT 5.7L) IAC RETURN
29 F855 18PK/YL 5 VOLT SUPPLY
30 K21 18DB/LG IAT SIGNAL
31 K41 18DB/LB O2 1/1 SIGNAL
32 K904 18DB/DG O2 RETURN (DOWN)
33 K43 18DB/LG O2 2/1 SIGNAL
34 K44 20DB/GY CMP SIGNAL
35 K24 20BR/LB CKP SIGNAL
36 K242 18BR/WT (EXCEPT 4.7L) KNOCK SENSOR NO. 2 SIGNAL
37 K924 18WT/BR (EXCEPT 4.7L) KNOCK SENSOR NO. 2 RETURN
38 K448 18TN/OR (5.7L) ETC MOTOR (-)
38 K61 18VT/GY (EXCEPT 5.7L) IAC MOTOR CONTROL
Re: Anyone have PCM wiring pin out diagram 04 RAM? [Re: SALEM1912] #466663
09/13/09 11:48 AM
09/13/09 11:48 AM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
C1 (don't know why text and connector POWERTRAIN CONTROL MODULE C1 (NGC) - BLACK 38 WAY CAV CIRCUIT FUNCTION
1 K98 18DB/YL (EXCEPT 3.7L) COIL CONTROL NO. 8
2 - -
3 K97 18BR/YL (4.7L) COIL CONTROL NO. 7
3 K97 18BR (5.7L) COIL CONTROL NO. 7
4 K28 18BR/LB (EXCEPT 3.7L) INJECTOR CONTROL NO. 8
5 K26 18BR/YL (EXCEPT 3.7L) INJECTOR CONTROL NO. 7
6 - -
7 - -
8 B222 20DG/WT (5.7L) VEHICLE SPEED SIGNAL NO. 2
9 Z130 16BK/BR GROUND
10 - -
11 F202 20PK/GY FUSED IGNITION SWITCH OUTPUT (RUN-START)
12 F1 16PK/WT FUSED IGNITION SWITCH OUTPUT (OFF-RUN-START)
13 B22 20DG/YL VEHICLE SPEED SIGNAL NO. 1
14 - -
15 - -
16 - -
17 - -
18 Z131 16BK/DG GROUND
19 - -
20 G6 18VT/GY OIL PRESSURE SIGNAL
21 C918 18BK/LB A/C PRESSURE SIGNAL
22 G31 18VT/LG AAT SIGNAL
23 - -
24 - -
25 D20 20WT/LG (5.7L) SCI RECEIVE (PCM)
25 D20 18WT/LG (EXCEPT 5.7L) SCI RECEIVE (PCM)
26 D16 18WT/OR (3.7L A/T/4.7L A/T 5.7L) SCI RECEIVE (TCM)
27 F856 18YL/PK 5 VOLT SUPPLY
28 - -
29 A919 20RD FUSED B(+)
30 T751 16YL FUSED IGNITION SWITCH OUTPUT (START)
31 K141 18DB/YL O2 1/2 SIGNAL
32 K902 18BR/DG O2 RETURN (UP)
33 K243 18BR O2 2/2 SIGNAL
34 - -
35 - -
36 D21 20WT/BR (5.7L) SCI TRANSMIT (PCM)
36 D21 18WT/BR (EXCEPT 5.7L) SCI TRANSMIT (PCM)
37 D15 18WT/DG (3.7L A/T/4.7L A/T 5.7L) SCI TRANSMIT (TCM)
38 D25 20WT/VT PCI BUS
Re: Anyone have PCM wiring pin out diagram 04 RAM? [Re: SALEM1912] #466664
09/13/09 11:52 AM
09/13/09 11:52 AM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
POWERTRAIN CONTROL MODULE C3 (NGC) - WHITE 38 WAY CAV CIRCUIT FUNCTION
1 - -
2 - -
3 K51 20BR/WT ASD RELAY CONTROL
4 - -
5 V35 20VT/OR (3.7L/4.7L) S/C VENT CONTROL
6 K173 18BR/VT CONDENSER FAN RELAY CONTROL
7 V32 20VT/YL (3.7L/4.7L) SPEED CONTROL SUPPLY
8 K106 18VT/LB NVLD SOLENOID CONTROL
9 K299 18BR/WT O2 1/2 HEATER CONTROL
10 K399 18BR/GY O2 2/2 HEATER CONTROL
11 C13 20LB/OR A/C CLUTCH RELAY CONTROL
12 V36 20VT/YL (3.7L/4.7L) S/C VACUUM CONTROL
13 - -
14 V32 20VT/YL (5.7L) BRAKE SWITCH NO. 2 SIGNAL
15 V937 20VT/BR (5.7L) S/C SWITCH RETURN
16 K167 20BR/YL (5.7L) APPS NO. 1 RETURN
17 K400 20BR/VT (5.7L) APPS NO. 2 RETURN
18 V38 20VT/OR (5.7L) S/C SWITCH NO. 2 SIGNAL
19 K342 16BR/WT ASD RELAY OUTPUT
20 K52 18DB/WT EVAP PURGE CONTROL
21 T41 20YL/DB TRS T41 SENSE
22 G113 18VT (EXCEPT 3.7L BASE) PTO SWITCH SENSE
23 B29 20DG/WT BRAKE SWITCH SIGNAL
24 - -
25 K23 20BR/WT (5.7L) APPS NO. 1 SIGNAL
26 - -
27 - -
28 K342 16BR/WT ASD RELAY OUTPUT
29 K70 18DB/BR EVAP PURGE RETURN
30 K66 18DB/WT (5.7L) P/S SWITCH SIGNAL
31 - -
32 K25 18DB/VT BATT TEMP SIGNAL
33 N4 20DB/WT FUEL LEVEL SENSOR SIGNAL
34 V37 20VT S/C SWITCH NO. 1 SIGNAL
35 K107 18VT/WT NVLD SWITCH SIGNAL
36 K29 20WT/BR (5.7L) APPS NO. 2 SIGNAL
37 K31 20BR FUEL PUMP RELAY CONTROL
38 T752 20DG/OR STARTER RELAY CONTROL
Re: Anyone have PCM wiring pin out diagram 04 RAM? [Re: SALEM1912] #466665
09/13/09 11:54 AM
09/13/09 11:54 AM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
POWERTRAIN CONTROL MODULE C4 (NGC) - GREEN 38 WAY CAV CIRCUIT FUNCTION
1 T60 18YL/GY OVERDRIVE SOLENOID CONTROL
2 T259 18YL/DG 4C SOLENOID CONTROL
3 - -
4 T118 18DG MS SOLENOID CONTROL
5 - -
6 T219 18YL/LG 2C SOLENOID CONTROL
7 - -
8 T59 18YL/LB UNDERDRIVE SOLENOID CONTROL
9 - -
10 T20 18DG/WT L/R SOLENOID CONTROL
11 T140 18YL/GY PRESSURE CONTROL SOLENOID CONTROL
12 Z908 18BK GROUND
13 Z977 18BK GROUND
14 Z904 18BK GROUND
15 T1 18DG/LB TRS T1 SENSE
16 T3 18DG/DB TRS T3 SENSE
17 T6 18DG TOW/HAUL OVERDRIVE OFF SWITCH SENSE
18 T515 20YL/DB TRANSMISSION CONTROL RELAY CONTROL
19 T16 18YL/OR TRANSMISSION CONTROL RELAY OUTPUT
20 T48 18BR/YL 4C PRESSURE SWITCH SENSE
21 T29 18YL/WT UNDERDRIVE PRESSURE SWITCH SENSE
22 T9 18DG/TN OVERDRIVE PRESSURE SWITCH SENSE
23 - -
24 - -
25 - -
26 T4 18DG/LB TRS T2 SENSE
27 - -
28 T16 18YL/OR TRANSMISSION CONTROL RELAY OUTPUT
29 T50 18YL/TN LOW/REVERSE PRESSURE SWITCH SENSE
30 T147 18DG/YL 2C PRESSURE SWITCH SENSE
31 T38 18YL/BR LINE PRESSURE SENSOR SIGNAL
32 T14 18DG/BR OUTPUT SPEED SENSOR SIGNAL
33 T52 18DG/OR INPUT SPEED SENSOR SIGNAL
34 T13 18DG/VT SPEED SENSOR GROUND
35 T54 18DG/OR TRANSMISSION TEMPERATURE SENSOR SIGNAL
36 - -
37 T42 18DG/YL TRS T42 SENSE
38 T16 18YL/OR TRANSMISSION CONTROL RELAY OUTPUT
Re: Anyone have PCM wiring pin out diagram 04 RAM? [Re: SALEM1912] #466666
09/13/09 03:29 PM
09/13/09 03:29 PM
Tampa FL
hemibeep Offline OP
hemibeep  Offline OP
Tampa FL
wow thank you all. I will let the fun begin....
thank you, thank you, thank you..
