Re: 470 Stroker
[Re: 76dodgeboy]
#466169
09/12/09 01:08 AM
09/12/09 01:08 AM
Posts: 43,303 Bend,OR USA
Cab_Burge
Is the 470 stroker(chevy rod journals)good. Im not keen on strokers and woder what this intales. I have a 400 block and can get a 470 crank with chevy journals. What else do I need. It will end up in a truck. Thanks to who reply
Rods, pistons to match the stroke, rod length and deck hieght with the compression ratio you want, don't forget the combustion chamber size and head gasket bore and thickness when ordering the pistons. You also will need rod bearings, rings and wrist pins, keepers if you want full floating pistons, rods and pins, balance the rotating assembly with either a nuetral balance balancer and flex plate or a external balancer and flex or converter
Re: 470 Stroker
[Re: 76dodgeboy]
#466173
09/12/09 12:42 PM
09/12/09 12:42 PM
Posts: 1,949 land of 10,000______'s
BDS871Cuda
Whats the total cost for the 470 stroker? You will have to add it all up. More money spent on buying extra parts seperately. It will make big TQ for a truck.
The 400 with the 440source 511 CI kit will make more TQ than the 470 inch and I would bet, cost less money. Streetable? You bet, all the pulling power you need with out reving it over 5000 rpm.
Any more info on your build?
Snap your neck, mega G-force launch, is all I want!
Re: 470 Stroker
[Re: BDS871Cuda]
#466174
09/12/09 12:57 PM
09/12/09 12:57 PM
Posts: 4,027 Dearborn Hts, MI
Sledge_57
Dearborn Hts, MI
If you're getting a good deal on the crank then the 470 might be the way to go. I like mine but be aware they like to rev so if you're looking for low revving big torque or if you're not getting a good deal on the crank I'd go bigger. I plan to go to 511 myself next build, size matters, ask any woman
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
Re: 470 Stroker
[Re: 76dodgeboy]
#466176
09/12/09 01:42 PM
09/12/09 01:42 PM
Posts: 9,892 Weddington, N.C.
Streetwize
Weddington, N.C.
My , the 470 combo is a better bang for the buck overall compared to the 4.15 crank 493-496; With the right compression, head and cam combo it can make near equal power so long as you have the valvetrain to carry the additional 400-500 rpm. For lighter A bodies the 470 9or even the 451) can even be an advantage in terms of tractible power to the ground in the more tire limited nose heavy combo. Theres NOTHING wrong with a 493 at all, it's just for my $$$ I'd build the 470 or..... For a heavier B or E body car with mid 3 to low 4 gears where you really want the highest average streetable torque over the widest powerband possible the 4.25" crank 511 is the best overall motor to build.....in all practical terms you really can't throw too much head at these monsters.
Re: 470 Stroker
[Re: Streetwize]
#466177
09/12/09 01:51 PM
09/12/09 01:51 PM
Posts: 8,064 Iowa
76dodgeboy
Iowa
Itll go in a truck and Ill probably run 4:10s So I can Drive it to Work on occasion. I live 25 miles from work, Interstate for the most part and It might get driven to the track witch is another 20-30 miles
Re: 470 Stroker
[Re: 76dodgeboy]
#466178
09/12/09 02:10 PM
09/12/09 02:10 PM
Sledge_57
Dearborn Hts, MI
I like the 511 like Streetwize said, however for $75 if that crank is good and you already have a block.....................
Doug
Re: 470 Stroker
[Re: Sledge_57]
#466179
09/12/09 02:16 PM
09/12/09 02:16 PM
Streetwize
Weddington, N.C.
for a Truck I'd build a ported 10:1 pump gas E-head 511 with either the RPM, a street dominator or the indy dual plane, a 950 HP, 4.10 gears, a Comp 251/257 @.050 Hydraulic and a tight 9 1/2" 3200 stall/4000 flash converter. it'll drive around town with all the manners of a sharp tuned but mildly warmed over 440...but it'll feel like that same motor with an unlimeted supply of 175 shot every time you nail it. But since you have the crank and rods (and if they're good to go) I'd use the same basic combo in a 470 and just knock the cam down to the 241/247XE, in that state it'll be down maybe about 50hp/60lb/ft to the 511 but at ardound 550 or so crank HP it will be a VERY STOUT trouble free daily driver. This is a basic "best bang for the buck, moderate RPM" combo, perfect for a mid 3 geared B/E or 4.10 geared truck. you want about 280-300cfm @.28" heads and look to get about 265 @.400 for it to really shove you in the back. The mid lifts are where it's at on the street....remember your cam spends a good bit of it's useable duration between that 1/3 and 2/3 open window....and in a non roller type app you're not hanging the valve open over the nose so the peak lift flow just isn't as critical. A 511 is about 10% (close to another cylinder's worth) larger so the end results will be roughly proportional, 470's with big solids and GOOD valvetrain can spin high enough to make 700hp and more easy when they have enough head, compression and cam. Run a BIG radiator and an aux cooler on the tranny and you're all set.
Re: 470 Stroker
[Re: Streetwize]
#466180
09/12/09 05:18 PM
09/12/09 05:18 PM
Posts: 8,064 Iowa
76dodgeboy
Iowa
I only have the block. I have never built a engine yet but plan to in the near future. My buddy will assist me in the process so no F$%k ups. I have a 383 that he owned. He bought the shortblock and its est at 510hp. He ran it in a 76 Fury with 4:10s and was in the low 12s IIRC with a single carb. He than went tunnelram and duels. Its going to be in another truck with 4:30s and a full spool.
