which KB pistons for a 451
#465714
09/11/09 04:30 PM
09/11/09 04:30 PM
RapidRobert
400 blk 3.75". rb crank. What part # (kb hyper) do I need to look at? Closed chamber heads & I would mill the quench dome to get ~9.5-10.1. thank you for your time.
Re: which KB pistons for a 451
[Re: RapidRobert]
#465715
09/11/09 05:09 PM
09/11/09 05:09 PM
Posts: 902 Seattle, WA
rss
Seattle, WA
KB215s??? IIRC, you responded to an earlier post of mine on stroker buids and were planning to use 440 rods for your 451. I think the KB 215s use a 383/400 length connecting rod instead of the 440 rod. I don't recall seeing a KB piston for the 451 that used the 440 rod. I think others (440Source, Diamond, Ross) have forged pistons for the 451 that use the 440 rod. I'm just beginning to look into this myself, so it is very likely that I could be wrong.
[Re: JohnRR]
#465717
09/11/09 06:03 PM
09/11/09 06:03 PM
Posts: 76 Sunny So. Cal.
mopar68
Sunny So. Cal.
For use with stock 440 rods web page And for stock 383 400 rods KB215 and KB251
[Re: RapidRobert]
#465720
09/11/09 06:43 PM
09/11/09 06:43 PM
RapidRobert
Thanks guys. Charles I have some felpro blue SB ones that are .054". The .051" ones you mention is that the compressed thickness of the BB versions of the same felpro blue gasket?
[Re: RapidRobert]
#465721
09/12/09 11:15 AM
09/12/09 11:15 AM
Posts: 75,020 U.S.S.A.
JohnRR
U.S.S.A.
no , most of the felpro BB blue gaskets are .040 nominal ...
[Re: JohnRR]
#465724
09/12/09 11:36 PM
09/12/09 11:36 PM
RapidRobert
alright I will order some KB 280's & mill the dome for quench distance. Any suggestions for a ballpark CR figure to shoot for (iron heads/stock cam/87 octane). Low rpm daily driver.
[Re: RapidRobert]
#465725
09/13/09 01:50 AM
09/13/09 01:50 AM
Posts: 8,716 Baltimore/Denver
64Post
Baltimore/Denver
Don't forget to consider your operating altitude. Approximate 10% static compression loss per 2500 ft.
Or not...
[Re: GwaiiEagle]
#465729
09/13/09 12:40 PM
09/13/09 12:40 PM
JohnRR
U.S.S.A.
The hassle is trying to find pistons for this combo in a .030 over. They are all 33 or 35.
4.375(.033 over) is a VERY POPULAR ring size AND it's what most GOOD off the shelf 400 based stroker pistons are sized at .
[Re: DrCharles]
#465731
09/13/09 01:07 PM
09/13/09 01:07 PM
JohnRR
U.S.S.A.
And he could always get file-to-fit rings and set the proper (large) top ring gap for the hypers
With hypers you don't need to go thru the hassle of getting a file fit ring , the std ring size for the give bore is your file fit ring , getting a .005 oversize is just making more work for oneself .
