What did it run??? #461262
09/06/09 10:49 PM
09/06/09 10:49 PM
The State of Hockey
2qik4u Offline OP
2qik4u  Offline OP
The State of Hockey
Racing a 12.5 index class. Time trials were:
12.61 @ 110.15
12.51 @ 110.96
12.64 @ 110.82
First round I'm way out front, thought the other lane had a bad light, so I run it just shy of the line and get out of it. Car goes 12.42 @ 107.83
What would it have gone had I stayed in it? A 12.3 would be a new personal best.
Re: What did it run??? [Re: 2qik4u] #461263
09/07/09 09:47 AM
09/07/09 09:47 AM
The State of Hockey
2qik4u Offline OP
2qik4u  Offline OP
The State of Hockey
For the morning crew...
I have to believe someone knows the answer or has a formula to estimte this?
Thanks!
Re: What did it run??? [Re: 2qik4u] #461264
09/07/09 11:39 AM
09/07/09 11:39 AM
Q
Quicktree Offline
Quicktree  Offline
Q
12.61 @ 110.15
12.51 @ 110.96
12.64 @ 110.82
you may have knocked off a few .01s.
Re: What did it run??? [Re: Quicktree] #461265
09/07/09 11:59 AM
09/07/09 11:59 AM
The State of Hockey
2qik4u Offline OP
2qik4u  Offline OP
The State of Hockey
I'm with you. If I dumped .03 it would have gone 12.39.
Tboomer, here the increments:
60 ft - 1.84
1/8 - 7.97
1/4 - 12.42
So was it on a 12.39 pass?
Re: What did it run??? [Re: 2qik4u] #461266
09/07/09 12:15 PM
09/07/09 12:15 PM
CheddarHead till October
weedlayer Offline
weedlayer  Offline
take the 1000' to 1320' from the other passes. add that number to the 1000' number of the dumped pass and you will have your estimated time.
that's assuming you did not dump on the other passes.
Re: What did it run??? [Re: weedlayer] #461267
09/07/09 12:23 PM
09/07/09 12:23 PM
The State of Hockey
2qik4u Offline OP
2qik4u  Offline OP
The State of Hockey
That makes sense, thanks Weedy!
The 12.42 was at B.I.R. It should be good for a 12.3 - 12.2 at the Rock.
