Re: Big block Ramchargers & Trail Dusters
[Re: smokn440]
#4612
07/26/04 09:38 PM
07/26/04 09:38 PM
Posts: 7,512 Lebanon ,PA in the Susquehanna...
70Challengerse
SMOKIN,If you answer your e-mails alittle more often,you wouldn't be saying that,did you even talk to Sam , about those bumper brackets,he has them, or are you spending to much time on that new KIDDY truck site , lol,now I forgot,what would you like to talk about,and NO black warlock ,not YET a love fest.lol,By the way I'm on the phone with Sam,he's is waiting for that e-mail about the brackets, DAMIT!
[Re: 70Challengerse]
#4614
07/26/04 11:01 PM
07/26/04 11:01 PM
Posts: 390 Hawaii
smokn440
super street
super street
Hawaii
ouch Ric ,,,go easy on me,,,,I check this site every time I'm online,,and I always answer my e-mails...and I had no idea Sam has A pair or I would have bought them already,,,,,,,but I did get my truck legal today,,,just a matter of gettn the rear bumber on now
No oil pressure in the 440 today!!!!!!!
[Re: smokn440]
#4615
08/01/04 12:43 AM
08/01/04 12:43 AM
Posts: 839 Dowell, IL
MrRico
super gas
super gas
Dowell, IL
MAN! I fired up the truck this afternoon, let it warn a bit and made a few passes up and down the road, pulled it back in and drained out the oil. Toped it off with new and refired the 440 and the oil PSI never came back up. Something is weird here, the shaft did not twist off, and it is full of oil, so I figure, must be the pump. The local parts guys in the area ( A-Zone, O'Reilly's Napa, All pro ) all said that a 440 oil pump will be special order. That will take a week or more! How about that for luck.
Re: No oil pressure in the 440 today!!!!!!!
[Re: MrRico]
#4617
08/04/04 09:58 PM
08/04/04 09:58 PM
Posts: 1,295 Hawley, Texas
shinnery
super street
super street
Hawley, Texas
Look in the pump you pulled off. Specially the relief valve. If you got something that blocked the valve open it will not prime and build oil pressure the next time you try to run it. My brother had a 383 that parts of the nylon cam gear did that to a couple of times. That relief valve is what determines your oil pressure so your new one must have a stiff spring. Bryce
Every electronic device is manufactured with smoke stored deep inside...
only a true genius can find a way to set it free.
The most terrifying words in the English language are: "I'm from the government and I am here to help!"
