vacume advance #460522
09/06/09 08:46 AM
09/06/09 08:46 AM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
a vacume adv. dist.still has the springs and weights in it,will it still adv. without the vac. hooked up?
Re: vacume advance [Re: bonefish] #460523
09/06/09 09:27 AM
09/06/09 09:27 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes it will ... up to the point of the mech advance
but the mech advance usually has some pretty stiff springs
EDIT
if it has both a mech and a vac advance... if just
a vac advance NO it wont.... the vac pulls the whole
plate to advance
Re: vacume advance [Re: MR_P_BODY] #460524
09/06/09 09:38 AM
09/06/09 09:38 AM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
the reason i ask ,this is on a race only car,496 rb 12-1 compr.and with the timing locked out its tough on the starter even with the crank and switch method.so i should be able to remove the vac,adv. off the dist. and put some lighter springs on it and it should work.or do i have to leave the adv. on the dist to hold the plate?
Re: vacume advance [Re: bonefish] #460525
09/06/09 09:45 AM
09/06/09 09:45 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I did this to my ealier dist in my race engines(340s)
and just used the mech advance.. had to re curve the
advance slots for the weights.. worked great(still
run that dist in my 395 stroker... back up engine).
Took the vac off of it
Re: vacume advance [Re: MR_P_BODY] #460526
09/06/09 10:32 AM
09/06/09 10:32 AM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
did you have to make the slots longer or shorter?
Re: vacume advance [Re: bonefish] #460527
09/06/09 10:36 AM
09/06/09 10:36 AM
Q
Quicktree Offline
Quicktree  Offline
Q
why don't you just pick up an MSD? very easy to tune.
Re: vacume advance [Re: Quicktree] #460528
09/06/09 11:06 AM
09/06/09 11:06 AM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
ive got msd on every thing else but this car is for sale cheap and i just want to get it perfect for the next guy.ill let him buy an msd.right now ive got more time than money.
Re: vacume advance [Re: bonefish] #460529
09/06/09 11:12 AM
09/06/09 11:12 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I had to weld them up some... I added more initial
timing and limited the advance to 16*
