Time to change out my Brake Booster...Any suggestions? #458800
09/04/09 12:27 AM
09/04/09 12:27 AM
Cochise County Arizona
SPWC Offline OP
SPWC  Offline OP
Im looking for the best,most effective way of replacing the booster on my wagon. Is there a way of doing it without removing the Master from the lines?Any suggestions?
Re: Time to change out my Brake Booster...Any suggestions? [Re: SPWC] #458801
09/04/09 08:41 AM
09/04/09 08:41 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
If the lines are in good shape it can be done. Just gently bend the lines as you move the master into a position that it will clear. If your not carefull you can kink the lines. I wouldn't try it if your lines are rusted over though. Then you are asking for a leak,
