Help me pick fuel filter or filters.. #458701
09/03/09 09:43 PM
09/03/09 09:43 PM
Indy
joshking440 Offline OP
Lunch is on me!
Lunch is on me!
Indy
500", turbo, blowthru e-85, red aeromotive mechanical fuel pump, fuel cell in the trunk.
Do I buy one filter, two filters, where do I put them. Are 2 over kill....
Re: Help me pick fuel filter or filters.. [Re: joshking440] #458702
09/03/09 11:01 PM
09/03/09 11:01 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
I like to run one filter before the pump. Some are easier to disassemble & clean than others. Make sure its flow capacity is as much as, or more than, your system - make sure it doesn't neck down inside - so it's not a restriction, and has as much filtration area as you can fit in its intended location.
