Anyone use F.A.S.T. air/fuel ratio meter? #458446
09/03/09 05:42 PM
09/03/09 05:42 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Just ordered this from Summit, going to give it a shot.
http://www.summitracing.com/parts/CCA-170402/
It has a one year warranty in writing....which looks like more than most.
The thing I like about it is, it doesn't require a laptop be carried around, it data logs right on the screen.
Anybody use it before? Any luck?
Re: Anyone use F.A.S.T. air/fuel ratio meter? [Re: ZIPPY] #458447
09/03/09 06:13 PM
09/03/09 06:13 PM
North Cackilacky
sdaurity Offline
sdaurity  Offline
North Cackilacky
I have a couple cars I have tuned have them but both have the optional rpm input which I really like. One is close to 2 yrs old now with 0 trouble.
One day I will have something cool here.
Re: Anyone use F.A.S.T. air/fuel ratio meter? [Re: sdaurity] #458448
09/03/09 07:18 PM
09/03/09 07:18 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Good to hear, thanks. Just hoping the thing works as advertised.
Re: Anyone use F.A.S.T. air/fuel ratio meter? [Re: ZIPPY] #458449
09/03/09 10:07 PM
09/03/09 10:07 PM
Wi.
old_racer Offline
old_racer  Offline
Wi.
Hi
I have it , for a race car you have to use the collector extensions to make it read right , other wize it worked good.
Russ
Re: Anyone use F.A.S.T. air/fuel ratio meter? [Re: old_racer] #458450
09/03/09 10:31 PM
09/03/09 10:31 PM
Mopar Lane,Mississippi
67HEMI Offline
67HEMI  Offline
Mine is 2 years old and the only thing I noticed was the o2's got a little lazy this spring so I replaced them right before Pinks in Belle Rose. Mine stays in my car all the time street or strip.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction) '69 Chrysler 300 Convertible 375 HP 440 '71 Plymouth Duster 360 W/EFI (Wife's Ride) '12 Ram MegaCab Dually 6.7 Cummins
Re: Anyone use F.A.S.T. air/fuel ratio meter? [Re: 67HEMI] #458451
09/03/09 11:39 PM
09/03/09 11:39 PM
Oklahoma
silverfish Offline
silverfish  Offline
Oklahoma
I've got this unit on my Duster. Haven't had a chance to use it much since I've only made 3 test passes since I installed it. I don't have the optional rpm software and I can already see that for a race car its a must. Otherwise you can't tell much about anything. It plays back in real time on the screen so its hard to get a good feel for the data. And with open headers it reads 0 at idle. It doesn't start to read anything until you get it under a load.
Re: Anyone use F.A.S.T. air/fuel ratio meter? [Re: silverfish] #458452
09/05/09 09:58 AM
09/05/09 09:58 AM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Thanks for the replies, appreciate that. Can't find anything negative on it, no buyer's remorse here.
I will be using it with an exhaust and mufflers mostly, which should hopefully help it work correctly.
Question: will using it with a pan evac mess it up?
No problem taking the evac hoses off with it, but I don't know whether to do that or just leave it alone.
