Re: Dana 60 or 9 inch
[Re: BobR]
#457194
09/03/09 12:10 PM
09/03/09 12:10 PM
Posts: 11,725 Portage,michigan
B3422W5
Portage,michigan
I wouldnt discredit a dana because of weight.
I swapped my broken 8.75 out for a dana and saw nothing ET wise by doing the swap, in spite of gaining about 35-40 pounds, and having added b body drum brakes on to the equation at the same time( a body 8.75 and smaller a body drums were what car had).. Must be the dana is effecient, and the weight is in a place it doesnt hurt.
[Re: B3422W5]
#457195
09/03/09 12:22 PM
09/03/09 12:22 PM
Posts: 1,090 north cakalaky
instigator
north cakalaky
Because a Dana or strange 60 just looks right sitting under a mopar...
65 Barracuda All aluminum Indy HEMI with some boost! COMING TO A TRACK NEAR YOU!
[Re: smokinwoody]
#457197
09/03/09 02:32 PM
09/03/09 02:32 PM
Posts: 1,418 Mcallen, TX
SB449VALIANT
Mcallen, TX
who cares what rear ya use!!!! run what ya brung and what you can afford..
and Happy Birthday Gilberto...
[Re: instigator]
#457198
09/03/09 06:44 PM
09/03/09 06:44 PM
Quicktree
as it does under a ford truck
[Re: Quicktree]
#457199
09/03/09 07:24 PM
09/03/09 07:24 PM
Posts: 5,895 Florida
Locomotion
That was one of Ford's "Better Ideas"!
[Re: RemCharger]
#457201
09/04/09 02:22 PM
09/04/09 02:22 PM
Posts: 102 Virginia
MACDiesel
Virginia
Check out the June '08 issue of Car Craft. They did a 9" vs 12bolt vs dana 60 shoot out. For the street, it kinda comes down to: when do you need a 9.75" ring gear? Or a super strong 9"? Then again, if your racing, bigger is better. The good ole 8 3/4 can handle a ton of power. Why not stick with the lighter (faster) set up? Oh yeah, a BIG, FAT to Car Craft for throwing the ford 8.8 in that article and leaving out the 8 3/4!
-1967 Belvedere II 440/4speed
[Re: MACDiesel]
#457202
09/04/09 02:30 PM
09/04/09 02:30 PM
Quicktree
well stick around a while and you will see a few dozen good ole 8 3/4s bite the dust. on a street car they will last forever. throw a real set of slicks, a little weight, and decent hp anf they are gone.
[Re: Quicktree]
#457203
09/04/09 04:32 PM
09/04/09 04:32 PM
Posts: 102 Virginia
MACDiesel
Virginia
Really? Even the build Moser ones?
[Re: MACDiesel]
#457204
09/04/09 04:38 PM
09/04/09 04:38 PM
Quicktree
the ring and pinion will always be the weak point no matter what you name it or how it's built. if I were going to use an 83/4 it would be an aluminum case.
[Re: B3422W5]
#457206
09/04/09 04:54 PM
09/04/09 04:54 PM
Quicktree
[Re: superwrench]
#457210
09/05/09 01:22 AM
09/05/09 01:22 AM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
I personally have never broke a 9"..I don't have enough power.. But I was in Denver for a race and wanted to try a 5.29 gear.. There were several guys that had spares for me to just pop in.. That was my personal experience. Now I have 2 sets of third members.. 1 for altitude.. Chris..
[Re: Chris'sBarracuda]
#457211
09/05/09 01:39 AM
09/05/09 01:39 AM
Posts: 2,470 Sydney,Australia
tex013
Sydney,Australia
Hi, thanks for all the ideas. dr diff thanks. anyone from down here knows how pricey any choice is to be made up. have borrowed a 4.1 8 3/4 for next weekend .if the car likes it through the trap it wll be a dana. if not a 9 inch. bearing in mind i have only been running a 3.91 rear gear. and yes it easier to obtain the 9 inch stuff BUT the dana is cooler we'll see thanks again Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
